No headlights...
Discussion in '6th Generation 2002-2013' started by Hans Olsson, May 31, 2019.
  1. Hans Olsson
    Hans Olsson New Member
    Sweden
    Eskilstuna Sweden.
    IMG_20190428_162932.jpg And no engine start unless i remove what I believe is the headlight fuse. Any thoughts?
  2. jstehman
    jstehman New Member
  3. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    IMG_20190601_055121.jpg IMG_20190601_060400.jpg Fuse f is for headlights i think.Battery is fine.
  4. squirrelman
    voltage to headlight goes through contacts in the START pushbutton.
  5. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    Here is what happens,I turn the key to on position and no headlights or fuel pump goes on.I push the start button, engine starts and stops when I let go of the button. I remove the fuse for the headlights and fuel pump runs normally and engine runs fine. No headlights of course.
  6. jstehman
    jstehman New Member
    Have you tried replacing the headlight fuse with a new fuse?
    Then I'd clean the start switch
    Sent from my SM-N950U using Tapatalk
  7. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    I have tried a new fuse,no change.I will clean the start switch. Thank you.
    jstehman likes this.
  8. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    Problem is with ground wire behind the cowl,also I have no lightning switch?
  9. Hans Olsson
    Sweden
    Eskilstuna Sweden.
  10. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    I found the cause.Too much load for the ground wire. IMG_20190604_173157.jpg IMG_20190604_173100.jpg
  11. jstehman
    jstehman New Member
    Toasty!
  12. Hans Olsson
    Sweden
    Eskilstuna Sweden.
  13. squirrelman
    they did it again !? honda often routes a single ground wire to return electrons from several components rather than using more grounds, causing overheating and failure. they always needed better electrical engineers on staff.
    later models (after '99) are worse cuz they used smaller-diameter wires !
    Hans Olsson likes this.
  14. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    Bike now has a second ground wire going back to near the battery.
