no low beam at all. VF700F
Discussion in 'Mechanics Garage' started by bobthebiker, Jun 20, 2011.
  1. bobthebiker
    bobthebiker New Member
    I'm stumped. all the connections are good, clean and solid, crank thebike, nothing. high beam comes on without fail, but low is DOA and nonop.
    any hints before I go mad? this would be on my 84 VF700F model.
    You've removed the bulb and put an ohmmeter on the terminals to check the filaments for continuity ??
  3. bobthebiker
    tested with a known good bulb, an HID kit, and a few others, nothing gets power. at all. its like the switch is DOA, but I'm not sure thats the case.
  4. squirrelman
    Replace the switch or very carefully take it apart and inspect/ clean contacts.
  5. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    You could try bypassing the switch with a jumper wire for verification. My turn signal switch get sketchy after the bike sits in the rain. Work it back and forth a couple times and she clears up.
  6. bobthebiker
    Got it. you guys once again were right. disassembly and cleaning the switch contacts did the trick. nice and bright contacts=nice and bright light.
