No spark on number 3 87 vfr700f2
Discussion in '1st & 2nd Generation 1983-1989' started by artee, Sep 1, 2013.
  1. artee
    artee New Member
    Rochdale,
    At the back, over the number plate. Look for the red plugs.
    You need to unscrew a small plastic flap to gain access for removing the CDI unit.
    I've managed to remove the end cover on the box, but can't figger out how to remove circuit board without damage.
  3. 87vfr
    87vfr New Member
    The box opens up by placing a screw driver in the little square hole and prying gently till it pops out of place then it slides out
  4. squirrelman
    Mine won't slide out or move at all or i wouldn't b askin........ :homer:
  5. 87vfr
    87vfr New Member
    It will there are plastic rails it slides in and out on
