Not a VFR but still Honda coooool?
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, May 10, 2025.
  1. RogueRC24
    Oh and new Cush drives, I will always do this from now on no matter how good they look without touching. The crumbled upon removal. Lol
    CB8DF8AC-B50F-4639-B2C0-A7DA798517DE.jpeg 6EE14E38-A23C-4F69-9B5F-70129E565AE2.jpeg
    rc24dk likes this.
  2. mello dude
    Iran, Islamic Republic of
    Wow, that expansion chamber is gorgeous.
  3. RogueRC24
    They are my 2nd favorite components of the whole bike. Wheels are still my favorite aspect..MAGTEK and soft bronzy gold. :)
    mello dude likes this.
  4. RogueRC24
    Dam good that was quick. New impeller from T2Racing. They have a ton of badass 2smoke kit. But you have to have a Japanese phone # to order. My son found a work around but my window is down to 3 weeks. Do I buy more? I should. Hahaha.
  5. mello dude
    It's a rule in a motorcycle project, you have to buy more, you must buy more, the project never ever gets enough kit to call it finished!
  6. RogueRC24
    Also trying loctite SF790 gasket remover for the first time. Seems aggressive but super helpful. image.jpg
  7. RogueRC24
    Internets tonight! My son said wheels are a go if I find some.
    Captain 80s and mello dude like this.
  8. RogueRC24
    Prep for gasket complete.
  9. RogueRC24
    Housing cleaned up nicely. image.jpg coolant transfer and new oring installed. image.jpg New OEM hoses with fancy clamps. SAMCOs next go around.
    As many carbon brackets as I could get to reduce the steel count.
    Captain 80s likes this.
  10. RogueRC24
    The Ocho.Plate is in spec but I don’t know and can’t find anything on the cut tooth notches. They don’t match the basket or the other plates.
    Correction they are cutouts for clutch dampers. Assuming to make the dry clutch quieter. Only one friction has the cut outs.
  11. RogueRC24
    Put me Daughters kitty sticker from Japan on the carbon clutch cover. Lol
    sixdog and Captain 80s like this.
  12. RogueRC24
    So i did put the clutch back together without the dampers, but I will order some just in case they are crucial.
  13. RogueRC24
    Well we are getting closer.
    Parts on order from Japan.
    New coolant loaded ( wait for leaks).
    Overflow tank placed
    Radiator grill painted
    Tank mounted
    Wired up my Gear indicator light
    New clutch cable installed
    Throttle spring adjusted. Was the strongest throttle pull I have ever encountered.
    Still to go:
    Front fender
    Fork hardware
    Lower bodywork
    Fuel cap assembly
    here she is.
  14. RogueRC24
  15. mello dude
    Sooooo cool! :thumbs:
  16. RogueRC24
    "TODAY WAS A GOOD DAY"..Ice Cube
    My son sent me the gauge since it was specifically designed for the NSR250. It was basically plug and play although, the shift light won't work.
    They designed the pickup sensor to have the original inner steel rotor hub. Mine is EBC aluminum. So unless I wanna play with super glue I can't get a speed rating to tell me when to shift.
    I really just want the gear indicator anyway. It is such a small bike I find myself asking for 7th gear. lol
    This way I can just look down and see where I am, I hope. :)
    Oh and the Raiders actually looked good. Yay
  17. RogueRC24
    Kennyska likes this.
    Oh mama
  19. mello dude
    Whoa! :thumbs:
    Is that glare, or is that the super rare "S WA" supension on it?
