Not the Real '89 VFR -a mild custom
Discussion in 'General VFR Discussions' started by Skipper11, Feb 4, 2025.
    I have handled a bunch of these as I have disassembled a lot of parts bikes and wheels, so I always seem to have plenty of extras when rebuilding a bike.
    But if I needed some, it would absolutely be worth a try to source them alternatively (cheaper). The material doesn't feel that exotic or anything.
    Heat, crush, water, chemicals (like wheel cleaners - light acid).
    A real benefit would be to have a known good system where you could swap them out for comparison. Good luck and do report back.
    #41
  2. Skipper11
    Skipper11 New Member
    Brisbane
    Well - Yes! The Cure, all fixed and me somewhat wiser o_O
    Finally gave up after fitting new, home punched fibre washers and using the factory torque settings when fitting the discs back into place.
    So, I removed the front wheel yet again, un-bolted the discs and measured them for the umpteenth time and concluded that there was a very minor thickness variation around the disc circumference -0.03mm, in and out, with no rational explanation that I could give.
    Contacted a local manufacturer here in the Brisbane area (Metal Gear) and asked if he was prepared to take a look at them and give an opinion.
    He said "Yes" and subsequently measured the discs to inform me he found the thickness variation to be as much as 0.06 on one disc, the other a bit less
    and after placing both discs on his granite certified flat surface, one had a warp in it (He took me through into the factory and showed me this)
    "These are cheap, no brand Chinese knock offs, only fit to be thrown away - take them back to where you got them and get your money back."
    (I did, and they did give me a full refund!)
    Metal Gear sold me a set of their own discs which I fitted, and straight away there was no longer any vibration and the bakes worked as I might have expected.
    Incidentally the "no brand" discs were also 5mm thick (approx.) and were engraved with "minimum thickness 4mm" where Metal Gear say the factory thickness should be 4.5mm and minimum thickness 3.5mm.
    Metal Gear say any thickness variation beyond 0.01mm will be felt through the brake lever and create vibration when stopping, and this cannot be compensated for by floating calipers, and will "not" bed in with time.
    However, wheel mounting pad discrepancy, such as the existing 0.4mm (my measuring) on my bike can be compensated for by a properly operating "floating Caliper". In fact, this was one of the reasons floating calipers were used back in the days of early motorcycle disc brakes they told me. Higher precision machining on later manufactured bikes has subsequently permitted a number of variations to disc brake setup.
    I have learned my lesson! Even though I was purchasing the discs from a company that has its base in the UK, and the stock was delivered from the UK I was informed, I now believe it originated in China.
    #42
    Captain 80s likes this.
  3. Skipper11
    Brisbane
    A lot of water has passed under the bridge since last I wrote, not the least problem, a nasty skin cancer (PDS if you want to look it up) took rapid hold of my right ear and so far, has cost me 2/3rds of my ear removed, and now going though radiation treatment.
    Not to worry, my 50-year-old son and I had planned to attend the VJMC National Rally some 1350 km's away, by riding our bikes, with me on the VFR and he on one of his Suzuki's.
    However, it was not to be, but a gap in the treatment allowed us to put the VFR on a trailer and tow her down to Jindabyne in Southwest NSW. There were about 380 bikes registered for the rally and this turned out to be something of a record for our club.
    Once there, we shared the riding during the rally and had a good time together. The VFR 750 never put a foot wrong, worked like a clock, I even got to do a little "spirited" riding on those beautiful high country back roads, long sweeping bends one after another with almost no apposing traffic.
    The attached photo I took of my son as he left on one such ride, and even he is becoming a fan of the old bike, says it handles well and certainly has more get up n' go than he expected.
    #43
  4. Thumbs
    Thumbs Member
    Bath(ish)
    Best of luck with your treatment, nice photo
    #44
    Skipper11 likes this.
