oil consumption
Discussion in '1st & 2nd Generation 1983-1989' started by catalinredes, Oct 15, 2014.
Tags:
  1. Allyance
    Allyance Insider
    Germany
    East Bay, California
    NO!, no additives, which are friction modifiers, not good for wet clutches. I think once you have breather unplugged you should be all right.
  2. catalinredes
    catalinredes New Member
    Romania
    Simleu Silvaniei
    ok, thanks for the answer
  3. catalinredes
    Romania
    Simleu Silvaniei
    I did the compression test with the throtle open and the engine warmed up this morning and it was over 17 bar on all 4 pistons. I unplugged the breathe tube from the air case. I hope that now it's all right.
  4. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    17 bar is 246psi so that sounds very high to me. However if they are all close together, that's the most important thing. I still think you will find you are using oil. I doubt unplugging a breather is going to make much difference. Hope I'm wrong though.
