Oil
Discussion in 'Mechanics Garage' started by dcengineer, Jul 13, 2007.
  1. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    I tried the Liquid Wrench chain lube. It dried up/slung off preety quick. It's not as good as Bel-Ray. If you go on a long ride, take the whole can with you. You'll need it.:biggrin:
  2. nozzle
    nozzle New Member
    Southern Maryland
    Eddie:
    You are right, I have to put it on every morning. Nothing to make it "stick" to the chain. No shop's open on Sunday to go get a can, so I'm typing here. Thanks.
    - Paul
  3. eddievalleytrailer
    Jonesborough, TN
    It'll hold you over till you can get the good stuff.
  4. mello dude
    - I'm sure its slippery stuff!:biggrin:
    Ok in a pinch - but my belly button is going- um, you got to be kidding!:eek:
    I use the ProHonda HP Chain Lube. It has a combination of Moly and Teflon and dries out completely. No sticky gunk to sling off a my a mess of things. Great stuff. I get 20 - 22 thousand miles on my chains.
  5. nozzle
    nozzle New Member
    Southern Maryland
    I'll start a new thread....
  6. Spike
    Spike New Member
    Ditto
    I use the syn stuff in my bike, since it is subject to such abuse in the engine and the clutch. I tend to ride high on the tach. Changed at about every 5,000 miles. Couple hundred thousand miles on different bikes, never had any problems with the engines leaking. Never any clutch issues. I use the motorcycle specific Mobil 1 after reading an in depth analysis a few years ago in Motorcycle Consumer News. Prior to that I used the Honda or BMW specific synthetic oils.
    And then I use the regular dino stuff in the cars, also changed at about 5,000 miles, took one engine to 238,000 miles before I sold it, ran like a top, no engine issues.
  7. derstuka
    San Diego, CA
    And let's see somebody switch their girl's shampoo and conditioner and see what hell that raises.... :mad2: :yell: :boxing: :crutch:
  8. NeverlosT
    NeverlosT New Member
    Narragansett, RI
    So I changed my oil yesterday using Honda Spectro 10W-40, all went well, until I was putting the oil in....
    Each oil bottle has this terrible aluminum seal on the top, that you have to break, because for some rediculous reason, just a cap is not good enough. So I break the aluminum tops and bend them back. Pour oil into the engine there through the port using a yellow funnel.
    1 quart in, I watched a 1 cm sqaure piece of Aluminum foil from the inside of the oil can wander down the funnel into my engine. Aaaand time stood still. There is Nooooooo way to get it out from the top, theres too much stuff in there, I was sure I was screwed.:confused:
    So in hopes that the piece could be flushed into the oil pan and back out...
    I opened the drain plug again, and flushed oil through, nothing.
    Did the same thing again, using 2 more liters of oil, nothing.
    Yet again, this time shaking the bike around while I did it, nothing.
    Finally, I was ready to give up and pray that the oil filter got it before it got to anything, but I decided to fill her all the way up, and drain once more.
    2 seconds into the last drain, the piece of foil came out the drain plug.
    I dont think I have been that happy in years. Oil change took 3 HOURS. :eek:
    Now I had made a huge mess, and have to buy another few quarts of oil to fill the bike up, but please please people... BE CAREFUL ABOUT POURING OIL IN, WATCH OUT FOR DEBRIS!!!!!
  9. ZonaMan
    ZonaMan New Member
    Tucson
    I like these oil threads too. My $0.02, I had used the Honda syn blend and regulars for a while and it was OK, but on my last change I tried the Repsol oil. I really like how the bike peforms and shifts - better than the Honda oils IMO.
  10. nozzle
    nozzle New Member
    Southern Maryland
    Derstuka:
    Seriously now.... Would you use petro or synthetic for this? :confused:
  11. derstuka
    San Diego, CA
    My girl would be mad if I used anything but the best, and considering the amount of hair she has...full synthetic all the way! :biggrin:
  12. nozzle
    nozzle New Member
    Southern Maryland
    I'm wonder what hair your talking about after noticing your signature line again... :eek:
    It may be that additional friction a semi-synthetic provides would be advantageous... make certain it is not going to loose the correct feel between the pressure plates as the clutch cable is engaged.
  13. derstuka
    San Diego, CA
    Are we talking about women or bikes? Sorry, I got lost there. Somebody help me, help please! :fish:
    If we are talking about women, I hear ya! :whoo:
    As far as my signature line, that is a proven quote from the famous chinese philosopher Confucious! ha!
  14. Outlawz24
    Outlawz24 New Member
    Lloydminster Sask
    So what im reading out of all this is to run Motorcycle specific 10-40 oil...I have looked at the Amsoil once or twice and if i recall right one of their mc oils is even named Interceptor...hmmmmmm wasnt there as specific rating these oils needed to meet..something like SG or something along those lines?
  15. derstuka
    San Diego, CA
    The best advice I could give you without starting another oil war is to run whatever oil you want of the major brands, just know that a steady/consistent oil change interval is probably most important.
    However, personally I run Redline brand motorcycle specific full-synthetic 10w-40. 5w-50 is good stuff as well, and 20w-50 is usually for aircooled motors that get very hot. I believe in synthetic especially for bikes with gear driven cams as the "oil wear" factor from getting chopped up thru the gears is higher...IMO of course! Synthetic motorcycle oils should have reduced friction modifiers to be wet clutch safe.
    BTW, just make sure there is not any Teflon in any oil you run.
  16. Outlawz24
    Lloydminster Sask
    Would synthetic be ok in an older chain drive VF that has over 30000 kms on it?
  17. nozzle
    nozzle New Member
    Southern Maryland
    In My Humble Opinion: heck yeah....
  18. derstuka
    San Diego, CA
    As long as an engine is broken in from new with a couple thousand miles on it, hell yes, use synthetic....I would. Just make sure that it is motorcycle specific (AKA wet clutch safe). There are certain synthetic car oils that would be safe in your bike as well, however I still use motorcycle oils. Just look for JASM (think that is it) on the back of the oil quart which would mean it is meant for japanese motorcycles. As long as it says it is wet clutch safe all is well anyways. You can always call the oil manufacturer to clarify if need be.
  19. phaedrus54
    phaedrus54 New Member
    Oakland, CA
    Oil Comparison Study
    This thread made me do some research on automotive vs. motorcycle oil and I thought it would be interesting to pass on...
    http://www.xs11.com/stories/mcnoil94.htm
    Same general conclusion as the Oil FAQ on this website.
  20. RVFR
    LOL you asked, look what ya got. ok Amsoil FTW
