OK, how the h*ll do I get these damn plastic tabs out??
Discussion in '5th Generation 1998-2001' started by TNRabbit, Jul 10, 2013.
  1. Skifreak
    Skifreak New Member
    Washington State
    I believe that the concept for the "naked" bike came about during a VFR oil change or headlight replacement. Naked VFR anyone?
  2. marriedman
    marriedman New Member
    Germany
    Dayton, OH
    It can be done, but it isn't easy to make a good looking naked VFR. this is the first one that I saw that looked awesome IMO:
    Here is the build thread:
    My 95 Vfr-Sf Project: The Process - Third and Fourth Generation VFR's - VFR Discussion
    One can't just do a cut job and get a good naked bike!
  3. 34468 Randy
    I was wondering if that cross threaded brass nut is the same dimensions as the bras part of the well nut?. If so, maybe consider getting a new well nut, and with a sharp knife, remove the rubber collar surrounding it, then epoxy that bras nut into the spot where the stripped one was. Would that work?
  4. TNRabbit
    TNRabbit New Member
    Woodford, VA
    I'm pretty certain it is. Since the hole in the fairing appears to have been boogered out badly, I'll probably just get a regular brass insert for wood, then tap the hole & epoxy it in place. WAAAAAAAAY cheaper than the well nuts!
    Thanks~
