On the road - front wheel bearing. Help!
Discussion in 'Mechanics Garage' started by pgafuture, Apr 15, 2013.
  1. dino71
    dino71 New Member
    New Jersey
    Can't you just use the old dust seals?
  2. pgafuture
    pgafuture New Member
    Hampton, New Jersey, United States
    At Honda of Rockville md now. They are going to try and re-use the old seals.
    95$ to install isn't terrible I suppose. It would have been 45 if I could've taken the wheel off myself but I can't do it without a stand.
    Just wanted to thank everyone who replied and offered assistance and ideas, what a great brotherhood we've got here. I owe you all big time.
    The bearings were obtained from applied industrial technology in Alexandria VA. for 17 each. Kymco brand Japanese made.
  3. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    If you're bored and hungry, go over to Mike and Sons for a sub. It's in a lil hole next to 7-11.
  4. pgafuture
    I am full of a bad Ass cheese steak from there! Good stuff.
  5. dino71
    dino71 New Member
    New Jersey
    Are you saying that the "stealership" charged you $34 for a pair of bearings?
  6. pgafuture
    No, an industrial supply company
  7. Badbilly
    Sounds like he got the bearings from a supplier. The stealership got him for fifty bucks to pull his front wheel and re-install it. Just think, we have their name now and it will be on the net forever..
  8. Maggot
    Maggot New Member
    Park Ridge, IL
    Glad it all worked out.
  9. pgafuture
    Anyone know the bearings needed for the rear?
  10. Shmerick
    Shmerick New Member
    Kennesaw, Georgia
    This unfortunate episode has me thinking it's time to change mine on the 00. Are they pressed in or will they slide out without much work?
  11. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    They are pressed in. If you don't have a slide hammer type bearing puller be prepared to do some major cursing while banging the bearing out from the opposite side using a hammer and drift. I've got a bearing puller so let me know if you need help I'm up near Alpharetta/Johns Creek area. It will only cost you one Sweetwater IPA and 6 wings from Taco Mac
    Rollin
  12. Scubalong
    Rolling is Cheap :stripper: IPA and wings sound damn good right now. :thumb:
  13. thx1138
    thx1138 New Member
    Perth
    1990 Honda VFR750F A REAR WHEEL | Babbitts Honda Parts House
    Check the three sizes given with a bearing supply specialist, maybe not the one you got the fronts from though. They seemed a bit expensive. Never let a bearing shop know you are desperate, the price can go up several hundred percent as a result.
  14. Metallican525
    Rockville, Maryland
    As for the rear bearings, All Balls has worked fine for my 500, scored a set on fleabay cheap. I would try to save the existing seals as the ones in the kit did not fit tight enough but otherwise :thumbsup: On the other side of things my All Balls fork seal kit for my 800 fits perfectly so YMMV. As for the "pressed in" factor of the bearings, yes, they are "pressed in", technically speaking. A long flathead screwdriver will knock them out in five minutes and a decent bearing driver set will knock them back in just as quickly if not faster. This is all assuming you're a wee bit handy with a wrench though.
