Parting out an 86 VFR 700
Discussion in '1st & 2nd Generation 1983-1989' started by thewarriorhunter, Apr 6, 2015.
  1. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Look for cracks and flaking of the paint. I didn't see any. My frame on my 83 was bent slightly and the paint on the bend points flaked and cracked.
    #41
  2. thewarriorhunter
    thewarriorhunter New Member
    Fuel tank is sold.
    #42
  3. thewarriorhunter
    Both radiators are sold.
    #43
  4. Ghost
    Ghost New Member
    Kernersville, NC
    Shot in the dark... Rear Seat Cowl?
    #44
  5. thewarriorhunter
    So sorry man, I just sold it a couple days ago on Ebay, you would have gotten a much better price coming from the forums also :(
    Also both levers and fluid reservoirs are gone.
    #45
  6. mmsledhead3
    mmsledhead3 New Member
    Washington state
    Got parts, and bike ready from the shop. Thanks for the fast delivery and good parts
    #46
  7. thewarriorhunter
    Glad to help!
    Also to keep the list running on what's sold in case anyone is looking for other parts, a guy came by today and picked up several things so they are no longer available:
    sub frame
    alternator cover and bolts
    rear brake master cylinder
    shock and shock mounting bolts
    handle bars
    rear rim & sprocket
    i do still have a lot of bike left so if you're looking for something let me know.
    #47
  8. keensali
    keensali New Member
    Do you still have the fuse panel that mounts on the upper triple clamp(I think...lol)?
    #48
  9. thewarriorhunter
    I do. I can get you a picture when I get home.
    #49
  10. keensali
    keensali New Member
    Cool beans!!
    #50
  11. thewarriorhunter
    Fuse box is gone.
    If anyone want a straight frame with a clear title let me know. I will give you a ridiculous deal on it as I really want it out of my garage and no one locally seems to be after it.
    #51
  12. Joel845
    Joel845 New Member
    Joshua Tree
    Hello how much for the lower right fairing you posted? Also any chance you have the black thing that goes between the right side tank and fairing so you can't see between them?
    #52
  13. thewarriorhunter
    Right fairing is sold, and with that I have no more plastics/fairing pieces.
    #53
  14. Joel845
    Joel845 New Member
    Joshua Tree
    Got the right side fairing, my bike finally looks better. Thanks so much!
    #54
  15. thewarriorhunter
    Glad I could help. Hope you have a good ride this weekend!
    #55
  16. thewarriorhunter
    Quick question:
    What is the engine made out of? Rather than throwing the upper case and headers away I was going to see if I could scrap them for a few bucks. I thought I read aluminum somewhere but I can't find anything.
    #56
  17. Allyance
    Allyance Insider
    Germany
    Block should be aluminum with cast iron liners, heads, side covers, pistons, con rods, aluminum. Crank, gears steel. Scrap dealer should be able to tell you if block is worth anything.
    #57
  18. thewarriorhunter
    Cool, that's what I thought. Probably won't get much for them, but I drive by a couple scrap yards during the week so I can make an extra pit stop for a few bucks. Anyone want a lower case? It's pristine! Otherwise I'm going to scrap that as well because I've had zero interest in it and it's taking up space.
    #58
  19. desktopdave
    desktopdave New Member
    Pittsburgh, PA
    Wish I needed it; always seems a shame to scrap useful stuff. But what can you do if there's no interest?
    If they're anything like the older V4 motors, the top half of the motor and heads are very low purity aluminum. The upper case has cast iron cylinder liners and is worth very little. The heads are also low grade alu, given the bronze valve guides and steel valve seats. My scrapper graded it all as "contaminated aluminum castings", worth something nominal like $0.10/pound. I had stripped one head to see if it was worthwhile but it's too much pain for the gain. The cam covers, side covers and lower case were worth much more, rated as "clean alu castings", something like $0.40/pound.
    Wheels are the highest grade of vehicle aluminum IIRC, definitely worth a lot more, like $0.80/pound. Fans, stators and starter motors are also well worth recycling. I was also surprised to learn that brake rotors are worth more than mixed scrap steel; they're very high-grade cast iron and require very little processing.
    #59
  20. THRASHED
    THRASHED New Member
    San Dimas, CA
    Do you still have the left riders peg mount?
    #60
