I bought my 04’ used with a power commander 3. I’d like to unplug it to really feel the vtech as the way it is now you’d never know it had it. Very linear excelleration but choppy below 4K. What’s the easiest way to unplug it momentarily and the bike still run as stock? Since I’m pretty sure I’ll go back to it. Pics would be appreciated if possible.
I just remapped a friend's '03. You can revert to stock with your laptop and the PCIII software. It's really easy. It also sounds like you might benefit from a better map. I loaded a custom map called Coyze. Super smooth transition and no low RPM choppiness. My friend was blown away by the difference, and so was I. (his bike does have Scorpion slip-ons) But you can also disconnect the unit from the harness and bypass it, reverting to stock. It is located under the right side of the fuel tank, just trace the PCIII lead to it.
