Peer Pressure 1986 VFR700
Discussion in '1st & 2nd Generation 1983-1989' started by Colddevil, Dec 26, 2022.
  1. Colddevil
    Colddevil Member
    Wisconsin
    Got lucky on checking eBay periodically over the last few months to find a decent headlight replacement. The one I pulled out has a bunch of housing/mounting damage, and I wasn't sure which parts I was missing from it.
    Realistically I have no use for the other one, so it's likely destined for the bin next time I do a spring cleaning. If someone has use for it, let me know.
    tsmitty and Bazza like this.
    Nice score. Pull what you can (bushings, collars, etc) from the old one and bin it.
  3. Colddevil
    Colddevil Member
    Wisconsin
    Going to grab some of those smoke signals you posted in the other thread since my turn signals are destroyed as well.
    Tip to anybody else that's thinking about buying those from that seller... add them to your watch list. It's likely the seller will offer a discount to move the item. I did the same thing with the above headlight, and the guy dropped 25% or something the day after I added it.
    Maybe this is common knowledge to eBay pros--but it was news to me. I learned about it when my brother told me he uses it when he tries to move a bunch of his side hustle inventory.
    Bazza, Jim McCulloch and RogueRC24 like this.
    Just a warning, they are not "bolt on". You will have to remove (most - all?) the plastic welded insert that reduced the hole for the US turn signal stay and come up with a solution for the rear mount screw.
    Maybe you can convert for a surface mount, not "flush" mount.
  5. Colddevil
    Colddevil Member
    Wisconsin
    Hm. It's been a while since I've looked at the neglected VFR700. Realistically this thing is just going to keep getting shuffled to the bottom of the project list, but I wanted to start to piece a few things together to see if maybe I can get it rideable. Probably not legally rideable since the entire brake light fairing assembly is destroyed. But maybe I can get the tank and set on.
    • Fired up and runs
    • Fuel pump works (I wasn't sure which was inlet/outlet, so wanted to verify before cutting new lines)
    I'm trying to cut down the amount of projects I have since I keep getting deeper into this whole racing rigmarole. If anyone in the midwest ever finds themselves looking for a project '86 VFR, let me know. Until then though, I'm going to keep slowly plucking away at things.
    I need to do some cutting on the Airtech fairing to fit the brake lights. Still not clear on how it's actually going to mount since there are no mounting pegs, but thinking I might be able to get my buddy to 3D print some, and I can JB weld them into place. That'll wait until the snow is flying though.
    Also I maybe just wanted an excuse to share that I got to run the ASRA races at Daytona last weekend. If there wasn't a bike right in front of me proving you could drive up that banking, I don't think I would have done it. Unbelievable experience. I didn't run great, and the motor may be blown, so I missed half of my races, but an experience I'll never forget.
    Pretty sure it's a cooked exhaust valve on the SV. But that's actually why I started working on the VFR again. I need to start clearing out some of the boxes of things and items I have on shelves or hanging on the walls. The gear driven cam whine sounds so awesome.
    RogueRC24, Bazza and Jim McCulloch like this.
  6. RogueRC24
    That sounds like a good experience even if the SV is cooked for a little while. I can't remember, did you want that tail section? I am flushing out my garage a bit.
    Oh and I 3D printed some "nubs" for Big Red awhile back. I can look for the file if you want. It worked out well. Just epoxy them on once you are sized length wise.
    Bazza likes this.
  7. Colddevil
    Colddevil Member
    Wisconsin
    100% I would want that file, absolutely. I'll send my email address in a private message if you don't have it already.
    I'll know on the tail section in a week. I understand the desire to flush the garage of stuff you're not using. I just may have fallen into a full set of identical bodywork to mine.
    RogueRC24 likes this.
    Me too please
  9. straycat
    How did I miss that you have 3 SV650's now ?
    Fastdruid and RogueRC24 like this.
  10. RogueRC24
    ^^^ He was sneaking that in there wasn't he. lol
  11. Colddevil
    Colddevil Member
    Wisconsin
    It wasn't intentional. It's becoming a problem. My uncle raced that bike for about 15 years as well as his son. His son recently hung up the leathers and he's liquidating a lot of his bikes. I say one thing about "That's a nice looking SV you got there..." and then the damn thing ends up at my house.
    I think it has an electrical issue--likely reg/rec which is why I took an interest in some of the reg/rec symptoms people were posting about on here a few weeks ago. I made it 1.8 laps at road America be before it died and I pushed that thing back. If I start it and run it til hot, it'll eventually get to one cylinder and just die. I'm thinking it's heat related and not fueling related. So yea I've got three SV's and none that actually work right now.
    Hence my wanting to get some work done on the VFR now before I start turning everything into an SV storm in the house. That, and I really want to actually try riding the VFR. It feels like a damn tank compared to the VF500F!
    Roll a couple VF1000 around the shop for a while and the VFR will feel very light.
    Fastdruid and Colddevil like this.
  13. sixdog
    sixdog Insider
    You got that right Mike !!!
  14. Colddevil
    Colddevil Member
    Wisconsin
    If anybody in the Midwest is looking for a running project 1986 RC26 with a title, let me know. Realistically, I know it's not going to get the attention it should to get the bodywork in good-enough-for-street-riding for a while. I've just got too many race bike projects going on. I've learned that rebuilding engines is expensive. And I've also come to the conclusion that I'd hardly ride this bike even if it was in tip top shape given how little street riding I do and the fact I like the size of the 500 much more.
    I'm not looking to immediately move it and go through the whole craigslist/facebook marketplace nonsense. Not yet, anyway. I reached out to V4Dreams, and he's going to keep a lookout for me as well. $1000 is what I'd be looking for from someone on here. If we make it to summer and I can actually get it ridden and street legal with lights, I'll play marketplace roulette for a different number.
    I have not yet ridden the bike, so things like chain and tires have no miles on them. I had it running a couple months ago off the auxiliary fuel tank. I verified the fuel pump was working as well but didn't fill the tank since I didn't want to have to drain it again and verify it was totally dry.
    Album here: https://imgur.com/a/xBB4EnP
    (all pics were taken about a week ago besides the pictures of the carburetor on the table after it was reassembled with new fuel and air pipes)
    • Wisconsin Title in my name
    • 45,302 miles
    • Front Brake Master Cylinder Rebuilt
    • Clutch Master Cylinder Rebuilt
    • Front Brake Calipers Rebuilt - All Balls
    • Rear Brake Caliper Rebuilt - All Balls
    • EBC HH Sintered Front Brake Pads new
    • Clutch Slave Cylinder Rebuilt
    • Petcock Rebuilt - Parts Unlimited
    • Engine valves adjusted
    • EMGO air filter
    • Metal Air and Fuel Supply Carburetor Tubes
    • California Carburetor -- replaced original with donor from gracious VFRW user due to butterfly valve damage
    • New tygon fuel lines
    • OEM float valves, needles, and pilot jets--ordered genuine from jetsrus.com
    • JT Sprocket Front 16T
    • JT Sprocket Rear 46T
    • RK 530 Gold Chain
    • Headlight replaced with used from eBay due to damage on original mount tabs
    • Rear Wheel Bearings - All Balls
    • Front Wheel Bearings - All Balls
    • Front and Rear Wheels Powdercoated
    • 90 degree metal valve stems
    • BT-46 Bridgestone tires. Installed in 2023, no miles. 21XX Front, 22XX Rear
    • Front fork fluid replaced with 10W--seals not replaced, records state last replaced 2013
    • Oil change and filter with Rotella 15W40 conventional
    • Coolant change - standard green ethylene glycol
    • Lower Fairing Clips - ordered from Denmark as I couldn't find a set literally anywhere else
    • Speigler 2-piece front brake lines
    • Air Tech tail section--ordered as soon as they said they were going out of business, have not installed
    • MotoBatt Battery
    • Regulator/Rectifier replaced (not the fanciest mosfet) after determining OEM was shot. Voltage readings correct now. Was over-volting before
    • Fuel pump tested working by pumping into receptacle
    • Fuel tank cleaned with Evapo-rust and not leaking. Has not been refilled with fuel since. Testing was all done via auxiliary tank
    • Partial spare motor
    Just keep it in mind if you're looking. I'll probably have it and keep pecking at it for a while.
  15. Colddevil
    Colddevil Member
    Wisconsin
    Interesting... you know why everyone always gets those broken images that load if you click "reply" or "edit"? It happens if you copy/paste an image into the body of the post. If you use the "upload file" button, the images don't break.
  16. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    I would like to purchase your bike. Would have to arrange transport to Florida, so if you are OK with a hopefully short wait period while I get that lined up, we can move forward.
    I will send a PM.
    Thanks!
    Baz
    RogueRC24 and Colddevil like this.
  17. Colddevil
    Colddevil Member
    Wisconsin
    Well, forget about the bike being available. I'm going to be sending this bike south to Bazza since he's purchased it, and it'll have a lot better shot of pounding the pavement again in 2025 with him. We had a lengthy conversation about the bike (probably need to have at least one more), and now just need to figure out transport from here to there.
  18. Bazza
    Bazza Member
    Thanks,Matt - you're a good dude and I appreciate the opportunity to take over and get her across the finish line! Stoked! :)
  19. RogueRC24
    Noice!! Good job boyz!
    Bazza likes this.
  20. sixdog
    sixdog Insider
    Congrats Bazz
    Bazza likes this.
