Picked up an 87 VFR700 But....
Discussion in '1st & 2nd Generation 1983-1989' started by mpadgett88, Dec 5, 2012.
  1. crustyrider
    crustyrider New Member
    North Country, New York
    Look for the little arrows on the boots plus the notches...good luck
    #41
  2. mpadgett88
    mpadgett88 New Member
    medford, oregon
    one of the boots has a crack. where can i find new ones?
    #42
  3. motorhead1977
    motorhead1977 New Member
    Albany, NY
    Hi, Perhaps there is a knowledgeable board member here who lives nearby and could help you out? You reference "rust in the tank". I think you may have drawn enough rust flakes into the fuel outlet from the tank to clog that as well as the petcock. With the fuel valve shut off remove fuel line from the metal outlet line on tank and then using something to catch fuel in case it is not clogged, turn on the fuel valve. When nothing or next to nothing comes out you have verified this is the issue. I have resolved these situations by first running a piece of mechanics wire up the metal fuel line and releasing rust clogs and in addition, if necessary, blowing compressed air into the metal fuel line. If you use compressed air be sure the filler cap is loose to relieve any pressure that may result once the line/valve are clear. Once you have cleaned out the rust from the tank it would be advisable to replace the petcock. They are available from Direct Line Parts or vendors on E-Bay. When you get to rebuilding the carbs, DO NOT separate them from the plenum they are bolted to. Remove them as a unit. If you don't the fuel tubes that run between the carbs will break and they can be VERY hard to find. I have rebuilt more VF/VFR carbs than I care to recall. They are relatively simple but my suggestion is to find someone who comes highly recommended and have them do it for you. Well worth the money spent. PM me and I can give you some contact info for someone other than me. You are on your way to having a fabulous bike. :thumbsup: Good luck!
    #43
  4. motorhead1977
    Albany, NY
    Carb Boots here:
    Order 4 of part number 8 from the fiche. Both front and rear carbs use same part number.
    #44
  5. slowbird
    slowbird Member
    Toronto, Ontario.
    I was having all kinds of running issues with my old '86 VFR. Finally I just bought 4 Keyster carb kits and replaced all the jets. Ran fine after that.
    Good last choice.
    #45
  6. mpadgett88
    medford, oregon
    that was a yamaha kit man.
    #46
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    What was? :confused:
    #47
  8. crustyrider
    I think Slowbird just wrote the name of the rebuild kits...keyster carbs and it did an auto link to that set....
    #48
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    The forum automatically does that huh?
    So what if I write something like: girl on girl .....or.... dildos.
    What does it link? :rolleyes:
    #49
  10. TOE CUTTER
    It links you to Crusty's sister face book page.
    #50
  11. Jeff_n_Franklin_Tn
    Jeff_n_Franklin_Tn New Member
    Franklin, TN (Nashville)
    Absolutely!! Do not ever jump a motorcycle while the jump vehicle is running. (unless the jump vehicle is another motorcycle)
    #51
  12. Jeff_n_Franklin_Tn
    Yes it's possible. The old girls have to have a good battery for the electricals to operate correctly.
    #52
  13. mpadgett88
    medford, oregon
    THought I should all know the bike is running again and running smooth!
    #53
  14. Jeff_n_Franklin_Tn
    :thumbsup:
    #54
