Ping
Discussion in 'Mechanics Garage' started by NorcalBoy, Oct 24, 2013.
  1. Scubalong
    Randy need another drinks :rolleyes:
    My current schedule has me finishing out the year having spent over 300 days on the road. Considering it started out as a design idea and some notes jotted in a notebook, a main frame, engine bottom end, and a blown out shock and set of forks in August of 2012, I can live with the progress. Dealing with over 50 companies on 3 different continents can take a little time. The rims alone were a special order from Marchesini and took over 6 months to receive from Italy.....no excuses, just takes time.
  3. TOE CUTTER
    Just bust'n balls, gotta get my cheap shots in where I can.
  4. Badbilly
    No wonder it took so long for that wheel to get here, probably the first one ever ordered for a Boss Hoss.
    Those Italian dudes probably didn't realize how important our Princess really is, adding to the delay.
  5. NorcalBoy
    Engine Info:
    '06 CRF 450X bottom end - wider range ratio than 450R, better for street duty
    superfinish transmission gears
    '06 CRF450R Cylinder - Removes emission controls
    Factory Pro shift detent arm and spring
    Micro Blue lower end steel bearing kit
    Splitstream oversized water pump impeller with billet case spacer
    CP Fabrication oil cooler mod w/fully tig welded radiators
    Falicon reworked crank
    Tokyo Mods manual CCT
    Complete DP clutch - cryo treated
    Trail Tech 110w stator and RR
    Vortex digital/programmable CDI - 10 map capability with bar mounted selector for 2 maps - change on the fly
    '06 CRF450R head - 1mm oversize valves compared to 450X head
    CP 13.5:1 piston w/ unshrouded and blended valve pockets (with chamber mods = to 13:1) - Ceramic coated crown and lubricity coated skirts by Embee Performance
    DLC piston pin and cryo'd bearing
    DLC lifter buckets
    Faction nitrided SS valves, ti retainers, springs w/custom shims - cryo'd
    Blended combustion chamber - ceramic coated by Embee Performance
    Blended intake and exhaust bowls - exhaust tract ceramic coated by Embee performance
    Recut intake and exhaust valve seats w/ 5 angle exhaust seats
    '02 CRF450R cam - between Hot Cam stage 2 and 3 - degreed for mid to top power
    Falicon adjustable cam gear
    stainless race spec drilled centercase bolts
    Ti exterior engine bolts
    Powdercoated side cases w/ anodized plugs and dip stick
    Carb & airbox:
    New FCR MX carb
    Athena dual spray venturi jet kit
    R&D adjustable leak jet
    R&D flex jet fuel screw
    Tokyo Mods AP spring
    Tokyo Mods vent hose kit
    JD red needle kit
    Boyesen Power Wing
    Twin Air Power Flo filter kit - removes stock backfire screen
    Fully cut new airbox - as per HRC competition bulletin
    Expected output is 50-55 true hp on Factory Pro EC997 dyno - equal to 55-60 DJ hp (DJ correction is 1.10 of EC997) Estimated final weight is 220 lbs.
  6. reg71
    Sikeston, MO
    sounds interesting. are you building it for track duty with race style fairing or some type of super-moto?
  7. NorcalBoy
    plated super single in motard trim.
  8. NorcalBoy
    My chi is strong.
  9. Badbilly
    Mine is bigger.
    .[/QUOTE]
  10. Scubalong
    Damn Ron that bike is to nice to take to Cabo :pound:
    I guess you have to fly in for the party :rolleyes:
  11. vfourbear
    vfourbear New Member
    Cincinnati
    Can't tell from that list if it's a bike or a Mars Lander or another Large Hadron Collider.
  12. Badbilly
    For those who are into Hadron Colliders, another great subject and a stimulating read is the treatise on Fictive Locomotion in the thoracic ganglion of the crayfish.
  13. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    NCB:
    Have you looked at the Zeeltronic CDI over the Vortex?
    Didnt know if they offered something for the 4T crowd but help yield the same results we have found on our end.
    BZ
  14. Bubba Zanetti
    Delaware
    Nevermind, Zeel appears 2T only.
    Carry on!
    BZ
  15. TOE CUTTER
    How much does that oil cooler increase capacity? Looks like a mod I need. Aboot passed oot when I first read how little oil is in it stock.
  16. NorcalBoy
    The oil cooler increases the crank side oil capacity 50% +/-. Chris Parker is also one of the nicest guys you'll meet within the industry. I cannot say enough good things about Chris and his company, CPR Fabrication. He isn't doing a whole bunch of these due to the cost (approx. $1200 with the bulletproof right side rad). If you call him direct, I'm sure he would help ya out.
  17. NorcalBoy
    Hahahaha, Thanks Brother Beez. BTW, I sincerely hope that you and the family are well and that life is treating you good.
  18. Bubba Zanetti
    Delaware
    Hey NCB, thanks for the comment. Things are blessed, albeit a tad off at the moment, but blessed none-the-less.
    The two-stroke nuts I have been running with have been doing crazy research on what our next step should be in bike work. On our end our problem is two fold. One the 2T tuners are retired or dead and, as you know, when you make a 2T more poewerful they get peaky and unreliable. My friend John ownes and rides a 97 Aprilia RSR125 GP bike. It weighs 155 lbs an sits at 42HP at the rear wheel. Per Jan Thiel and others whose names I cannot pronounce the next break through for 2T's was electronics.
    Long and the short my riding has been pretty limited lately, but almost bought a Zeeltronic from a guy in the Netherlands who pulled it off his TZ125. Everyone who has one swears by them. The ability to keep a bike stock (basically ;-) but get rather large gains in HP is pretty impressive.
    John should see 50HP at the wheel on his Aprilia and I should see the low 40's with the TZ.
    Nice project you got going so keep posting pics!!!
    God Bless,
    Dan
  19. Joey_Dude
    Joey_Dude Member
    North Georgia
    :jaw: Did NorcalBoy actually say something nice?!?!?
