Pretending I know what I am doing.... The adventures of carbon fiber boy!
Discussion in 'General VFR Discussions' started by Baddabing, Sep 13, 2011.
  1. Baddabing
    Baddabing New Member
    Idaho
    My battle with carbon fiber sheets. Never have played with it before. First attempt at a heat shield turned out very well. Don't like that the only chrome was On the exhaust. Just did not fit the style of the bike.
    Before
    new shield
    After
    Love the look. Working on the cans heat shields now. A bit tougher than the little heat shields.
    After I get these done and mounted and take aday off from the cussing, and throwing stuff around my garage I will make a few other carbon fiber pieces, want to cover the dash and the front
    piece under the windscreen.
    Here is one of the cans.
    The small heat shield took about 45 minutes. The can shield took 3 hours. Have to paint the cans and pipes with some engine enamel before I can mount the shields.
    That is tomorrow's project, 1 more can, paint, then maybe cut the cat off and gut it and weld it back on.
  2. Baddabing
    Idaho
    Done. I really hate carbon fiber. I think I will take a break from it for a while.
  3. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Looks SICK!!!!!!! :thumbsup: Nice work sir
  4. Alaskan
    Alaskan Member
    Alaska
    Purdy.
  5. rcfoggy
    rcfoggy New Member
    Fairfield Ohio
    looks great
    Looks Great
    ,where did you get the carbon fiber?
  6. duccmann
    Try iJDMtoy.com
  7. Baddabing
    Idaho
    I got it from DragonPlate
  8. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    Really, REALLY nice lad. Looks particularly good on that pearly white bike.
  9. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Fits the bike nice. How did you affix the cf to the parts? Did you have to cure the cf? I've never worked with it and could think up some projects though using it.
  10. 34468 Randy
    Very nicely done Baddabing. Really set off well with those white wheels. I may just have to follow suit with that. Now you need a smoked windscreen to finish it off.
    On another note, is that a couple of nice burls I see leaning against the wall in the back ground?
  11. Baddabing
    Idaho
    I used sheet carbon fiber and used a heat gun and a halogen work light to soften the sheet enough to form it to the old cans and heat shield. Made the mounting tabs and mounted them to the proper spots on the back. I was going to overlay, but it just didn't look right, added extra bulk around the ends where it folded over.
    I have the block off pieces coming for the grab handles, I have enough left over to make them out of carbon fiber. Looking for a good smoke screen.
    Not Burl wood, flagstone, I used to live by Salmon Idaho and they had a U Pick rock quarry. I had a friend working there and would call when
    they brought a load down to the u pick pit. Got lucky and found a good 4 foot long, 2 1/2 wide and about 12 inches thick. A rock hammer and wide chisel and bobs you uncle I had about 5 good slabs out of it. I have 3 left. Made mom and dad two benches and a fire pit out of some smaller slabs.
  12. Baddabing
    Idaho
    Grab rail block off plates made and mounted.
  13. Big.Tater
    Big.Tater New Member
    Kyle, TX
    Beautiful bike and SICK exhaust covers! I like it a LOT!
  14. woody77
    woody77 New Member
    Palo Alto, CA
    Could you do a how-to write-up on the CF? (or at least point to one that you followed?) 'cause that looks great, and I've been looking for ways to forming CF without going all-out with a mold/resin/etc. I hadn't thought about using pre-preg and a heat gun.
  15. goinphaster
    goinphaster New Member
    California
    yes please do. when you get done with your hiatus, you care to teach us, sensai?
  16. Matasickle
    Matasickle New Member
    CT
    Amazing work, sir.
    I too, would love a "how-to" write up.
  17. 82ndGreasemonkey
    82ndGreasemonkey New Member
    S. GA
    That looks amazing!
    Your bike (being white) brings it all out nicely.
  18. tinkerinWstuff
    I have a local plastic shop that carries CF.
    you folks might try poking around your local neighborhoods
  19. DaHose
    DaHose New Member
    Napa, CA.
    TAP plastics carries CF sheet. Don't know about pre-preg.
    Jose
