Problems with wind
Discussion in 'Mechanics Garage' started by Ingmarcus, Sep 15, 2015.
  1. Badbilly
    SOW alleviated his wind problem with daily double doses of Beano. No carburetors were harmed.
  2. Lint
    Lint Member
    Simi Valley, Ca.
    My only problem with wind is diet related.
  3. Gator
    Gator Member
    Did you read this? ^^^^!
  4. squirrelman
    No, i experienced it on every Hawk i owned (4). The Hawk is my regular daily ride, seldom need the speed or long distance capability of my VFRs.
  5. Gator
    Gator Member
    No Squirrelman, I was asking the OP and others posters if they read your post, no one addressed your answer. It seemed they missed it. Seems like you have the answer and they did not see it.
  6. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    (I think he was talking to the original poster, Squirrelman. Not you, bunky).
  7. Gator
    Gator Member
    Yes sir, thanks.
  8. squirrelman
    Guess i misunderstood..........:confusion:
  9. duccmann
    Well...update!!!
  10. Knight
    Knight New Member
    USA
    Only two days have gone by. He may not have time until the weekend to even touch the bike. He said he would respond so let us give him some time to respond.
  11. Badbilly
    Si Jefe! When do you pass oot the pesos?
  12. sunofwolf
    sunofwolf New Member
    Yes type in ignore old v4tofart- Monks bite back:chaingun:
  13. Ingmarcus
    Ingmarcus New Member
    Yes I read it. Sorry but Ive been at work and havent had much time getting to the bike. I will post an update reply that is a bit more informative in the weeke d :)
  14. Ingmarcus
    Will check that. Thanks :)
  15. Ingmarcus
    Thanks for the welcome :)
  16. Ingmarcus
    Correct, thanks for that :)
    So, as stated I havent had much time yet to do any of the helpful tips you guys sent me. And I want to say I appreciate all of your active helpfulness in trying to solve this strange problem. Check list for the weekend: vent tubes, start spray to check leak, air compressor test, fuelpump relay. I have checked: exhaust which is fine btw. Again I will update as soon as something new happens :) Thanks again!
  17. Ingmarcus
    Update as promised :)
    The air compressor test showed nothing, blew on all components possible. Start spray showed no leak. Fuelpump relay not yet checked.
    Things I found: upon removing the fueltank I found a smal filter attached to the side, I removed it and the filter fell apart upon contact so I changed it. Also found that the cowl infront of the airintake was not properly attached to the frame, fixed that. Ran the bike and sure enough, it started running weak as soon as it got windy. So that leaves the vent tubes. Took the vent hoses that run down between the rear wheel and the shock absorber, they were taped together (?). I tried squeezing them as I drove the bike and it would show the exact same behaviour. I then pointed them forward as I drove and voila! Bike ran like a champ :)
    Im going to ride some more in the week to make sure its actually solved. Thus I will keep you updated should it not work out. So thanks for all the great replies and the help you guys gave me. A big thank you to TOE CUTTER for the vent tube idea :)
  18. TOE CUTTER
    I love a happy ending!!!!!! :Cry:
