I purchased a pristine 2000 Honda VFR800 Interceptor last year and it came with this Procom Power Jet Fuel Controller (PE-JP-007) still in the box and looks like it was never installed. I just checked online and new they retail for $139 (see first pic), and this unit will fit many other motorcycles as well (see below). $50 Or Best Offer (OBO) From Procom/ElectroSport website: https://www.electrosport.com/products/pe-pj-007-powerjet-fuel-controller Most fuel injected engines run very lean and this is fine except for when demanding maximum power output on the track, especially when you have sport exhausts installed. Being able to simply adjust the fuel/air ratio in those conditions would be wonderful wouldn't it? The PowerJet Fuel Controller allows just that! You can adjust the fuel map from -4% to +10% by selecting one of the seven settings. We even incorporated a stock setting which means no change compared to stock. Our PowerJet is a simple yet complicated device. It measures the outside air temperature very close to where the stock sensor is located, and adjusts the signal from the OEM air temperature sensor to the ECU to make use of the built in Air Temperature Correction factor that is built into every stock ECU. What this accomplishes is that the ECU is told that the intake air is a little cooler than it is, and the ECU will respond by injecting a fraction more fuel depending on the PowerJet setting. You as a rider will notice a substantially improved engine response when you twist the throttle. The neat thing is that when under constant load (constant speed) the oxygen sensor in the exhaust will make the ECU correct the fuel/air ratio back to stock! However, as soon as the system notices an increase in power it switches from closed loop (oxygen sensor feedback) back to open loop (no feedback) and will correct the fuel/air ratio by the amount you selected on the PowerJet. PowerJet can be easily installed by plugging it in between the stock AIT sensor which is usually located somewhere on the airbox and the bike's wiring harness. Each PowerJet comes with the exact plug in connectors and installation will normally only take a few minutes. Finding the air temperature sensor usually takes more time than plugging in the PowerJet. You can leave the PowerJet sitting under the bodywork somewhere as it is designed to be rugged and waterproof. After figuring out what setting works best with your specific engine/exhaust/intake combination you typically do not need to adjust it any more. This product is known to fit: 1986 HONDA CB700SC Nighthawk S 1998 HONDA VFR800Fi Interceptor 1999 HONDA CBR1100XX Blackbird 1999 HONDA VFR800Fi Interceptor 2000 HONDA CBR1100XX Blackbird 2000 HONDA CBR900RR / CBR929RR 2000 HONDA RVT1000R RC51 2000 HONDA VFR800Fi Interceptor 2001 HONDA CBR1100XX Blackbird 2001 HONDA CBR600F4i 2001 HONDA CBR900RR / CBR929RR 2001 HONDA RVT1000R RC51 2001 HONDA VFR800Fi Interceptor 2002 HONDA CB900F / CB919 Hornet 2002 HONDA CBR1100XX Blackbird 2002 HONDA CBR600F4i 2002 HONDA CBR900RR / CBR954RR 2002 HONDA RVT1000R RC51 2002 HONDA ST1300 Pan European 2002 HONDA VFR800 Interceptor / VFR800A 2002 HONDA VTX1800 /R /N /T /F 2003 HONDA CB1300 2003 HONDA CB900F / CB919 Hornet 2003 HONDA CBR1100XX Blackbird 2003 HONDA CBR600F4i 2003 HONDA CBR600RR 2003 HONDA CBR900RR / CBR954RR 2003 HONDA RVT1000R RC51 2003 HONDA ST1300 Pan European 2003 HONDA VFR800 Interceptor / VFR800A 2003 HONDA VTX1800 /R /N /T /F 2003 HONDA XL1000V Varadero 2004 HONDA CB1300 2004 HONDA CB900F / CB919 Hornet 2004 HONDA CBR1000RR 2004 HONDA CBR600F4i 2004 HONDA CBR600RR 2004 HONDA RVT1000R RC51 2004 HONDA ST1300 Pan European 2004 HONDA VFR800 Interceptor / VFR800A 2004 HONDA VTX1800 /R /N /T /F 2004 HONDA XL1000V Varadero 2004 SUZUKI AN400 Burgman 2005 HONDA CB1300 2005 HONDA CB900F / CB919 Hornet 2005 HONDA CBR1000RR 2005 HONDA CBR600F4i 2005 HONDA CBR600RR 2005 HONDA RVT1000R RC51 2005 HONDA ST1300 Pan European 2005 HONDA VFR800 Interceptor / VFR800A 2005 HONDA VTX1800 /R /N /T /F 2005 HONDA XL1000V Varadero 2005 SUZUKI AN400 Burgman 2006 ARCTIC CAT 700 EFI /SE/FIS/TRV 2006 HONDA CB1300 2006 HONDA CB900F / CB919 Hornet 2006 HONDA CBR1000RR 2006 HONDA CBR600F4i 2006 HONDA CBR600RR 2006 HONDA NT700V - Deauville 2006 HONDA RVT1000R RC51 2006 HONDA ST1300 Pan European 2006 HONDA VFR800 Interceptor / VFR800A 2006 HONDA VTX1800 /R /N /T /F 2006 HONDA XL1000V Varadero 2006 SUZUKI AN400 Burgman 2006 SUZUKI LT-R450 Quadracer 2007 ARCTIC CAT 700 EFI /SE/FIS/TRV 2007 HONDA CB1300 2007 HONDA CB900F / CB919 Hornet 2007 HONDA CBR1000RR 2007 HONDA CBR600RR 2007 HONDA NT700V - Deauville 2007 HONDA ST1300 Pan European 2007 HONDA VFR800 Interceptor / VFR800A 2007 HONDA VTX1800 /R /N /T /F 2007 HONDA XL1000V Varadero 2007 SUZUKI AN400 Burgman 2007 SUZUKI GSX-R1000 2007 SUZUKI LT-R450 Quadracer 2008 ARCTIC CAT 700 EFI /SE/FIS/TRV 2008 ARCTIC CAT 700 H1 EFI 2008 ARCTIC CAT PROWLER XTX 2008 ARCTIC CAT THUNDERCAT 1000 2008 HONDA CB1300 Super Four 2008 HONDA CBR1000RR Hurricane 2008 HONDA CBR600RR 2008 HONDA NSA700A - DN-01 2008 HONDA NT700V - Deauville 2008 HONDA ST1300 Pan European 2008 HONDA VFR800 Interceptor / VFR800A 2008 HONDA VTX1800 /R /N /T /F 2008 HONDA XL1000V Varadero 2008 SUZUKI AN400 Burgman 2008 SUZUKI GSX-R1000 2008 SUZUKI GSX-R1300 Hayabusa 2008 SUZUKI GSX-R600 2008 SUZUKI GSX-R750 2008 SUZUKI LT-R450 Quadracer 2009 ARCTIC CAT 500 H1 TRV 2009 ARCTIC CAT 550 H1 / 550 H1 EFI 2009 ARCTIC CAT 700 H1 / 700 LTD 2009 ARCTIC CAT 700 HI CRUISER 2009 ARCTIC CAT 700 MUD PRO 2009 ARCTIC CAT PROWLER 550 / 550 XT 2009 ARCTIC CAT PROWLER 700 XT 2009 ARCTIC CAT PROWLER XTX 700 2009 ARCTIC CAT PROWLER XTZ1000 2009 ARCTIC CAT THUNDERCAT 1000 2009 HONDA CB1300 Super Four 2009 HONDA CBR1000RR Hurricane 2009 HONDA CBR600RA 2009 HONDA CBR600RR 2009 HONDA NSA700A - DN-01 2009 HONDA NT700V - Deauville 2009 HONDA ST1300 Pan European 2009 HONDA VFR800 Interceptor / VFR800A 2009 HONDA XL1000V Varadero 2009 SUZUKI AN400 Burgman 2009 SUZUKI GSX-R1000 2009 SUZUKI GSX-R1300 Hayabusa 2009 SUZUKI GSX-R600 2009 SUZUKI GSX-R750 2009 SUZUKI LT-R450 Quadracer 2010 ARCTIC CAT 1000 MUDPRO / H2 2010 ARCTIC CAT 500 H1 TRV 2010 ARCTIC CAT 550 H1 / 550 H1 EFI 2010 ARCTIC CAT 550 S EFI 2010 ARCTIC CAT 700 H1 EFI / 700 LTD 2010 ARCTIC CAT MUDPRO 700 H1 EFI 2010 ARCTIC CAT PROWLER 550 / 550 XT 2010 ARCTIC CAT PROWLER XTX 700 2010 ARCTIC CAT PROWLER XTZ1000 2010 ARCTIC CAT TBX700 H1 / LTD - EFI 2010 ARCTIC CAT THUNDERCAT 1000 H2 2010 ARCTIC CAT TRV1000 H2 EFI / CRUISER 2010 ARCTIC CAT TRV500 S EFI / HI EFI 2010 ARCTIC CAT TRV550 S EFI 2010 ARCTIC CAT TRV700 H1 EFI / 700 CRUISER 2010 ARCTIC CAT TRV700S EFI 2010 HONDA CB1300 Super Four 2010 HONDA CBR1000RR 2010 HONDA CBR600RA 2010 HONDA CBR600RR 2010 HONDA NSA700A - DN-01 2010 HONDA NT700V - Deauville 2010 HONDA ST1300 Pan European 2010 HONDA VFR1200F 2010 HONDA XL1000V Varadero 2010 SUZUKI GSX-R1000 2010 SUZUKI GSX-R1300 Hayabusa 2011 ARCTIC CAT 1000 LTD / 1000 GT 2011 ARCTIC CAT 1000 MUDPRO / H2 2011 ARCTIC CAT 550 / 550 TIMBER 2011 ARCTIC CAT 550 H1 / 550 H1 EFI 2011 ARCTIC CAT 550 S EFI 2011 ARCTIC CAT 550 TRV / GT / Cruiser GT / LTD / CAT 2011 ARCTIC CAT 700 CRUISER / 700 TRV 2011 ARCTIC CAT 700 GT / LTD 2011 ARCTIC CAT 700 H1 EFI / 700 LTD 2011 ARCTIC CAT 700 TRV GT / 700 TRV 2011 ARCTIC CAT MUDPRO 700 H1 EFI 2011 ARCTIC CAT PROWLER 550 / 550 XT 2011 ARCTIC CAT PROWLER HDX / -Timber Camo 2011 ARCTIC CAT PROWLER XTX 700 2011 ARCTIC CAT PROWLER XTZ1000 2011 ARCTIC CAT TBX700 H1 / LTD - EFI 2011 HONDA CB1300 Super Four 2011 HONDA CBR1000RR 2011 HONDA CBR600RA 2011 HONDA CBR600RR 2011 HONDA NT700V - Deauville 2011 HONDA ST1300 Pan European 2011 HONDA XL1000V Varadero 2011 SUZUKI AN400 Burgman 2011 SUZUKI GSX-R1000 2011 SUZUKI GSX-R1300 Hayabusa 2011 SUZUKI GSX-R600 2011 SUZUKI GSX-R750 2012 ARCTIC CAT 1000 CRUISER 2012 ARCTIC CAT 1000 GT / TRV GT 2012 ARCTIC CAT 1000 MUDPRO 2012 ARCTIC CAT 550 / 550 TIMBER 2012 ARCTIC CAT 550 TRV / GT / Cruiser GT / 550 LTD 4x4 2012 ARCTIC CAT 700 CRUISER / 700 TRV 2012 ARCTIC CAT 700 GT / LTD / TRV GT 2012 ARCTIC CAT 700 MUD PRO / LTD 2012 ARCTIC CAT 700 RED / 700 GREEN 2012 ARCTIC CAT 700 TBX GT 2012 ARCTIC CAT PROWLER HDX / -Timber Camo 2012 ARCTIC CAT PROWLER XT 2012 ARCTIC CAT PROWLER XTX 2012 HONDA CB1300 Super Four 2012 HONDA CBR1000RR 2012 HONDA NC700X 2012 HONDA NT700V - Deauville 2012 SUZUKI AN400 Burgman 2012 SUZUKI GSX-R1000 2012 SUZUKI GSX-R1300 Hayabusa 2012 SUZUKI GSX-R600 2012 SUZUKI LT-Z400 Quadsport 2013 ARCTIC CAT 1000 XT 2013 ARCTIC CAT 500 XT 4x4 2013 ARCTIC CAT 550 TRV XT 4x4 / Core 4x4 / Limited 4x4 2013 ARCTIC CAT 700 Limited 4x4 / 700 XT 4x4 / TRV700 Limited 2013 ARCTIC CAT 700 MUD PRO / LTD 2013 ARCTIC CAT MUDPRO 1000 Limited 2013 ARCTIC CAT PROWLER 550 / 550 XT 2013 ARCTIC CAT PROWLER HDX 4x4 2013 ARCTIC CAT PROWLER XTZ1000 2013 ARCTIC CAT TBX700 XT 4x4 2013 ARCTIC CAT TRV1000 Limited / 4x4 2013 ARCTIC CAT TRV500 CORE 4x4 2013 HONDA CB1300 Super Four 2013 SUZUKI AN400 Burgman 2013 SUZUKI GSX-R1000 2013 SUZUKI GSX-R1300 Hayabusa 2013 SUZUKI GSX-R600 2013 SUZUKI GSX-R750 2013 SUZUKI LT-Z400 Quadsport 2014 SUZUKI GSX-R1000 2014 SUZUKI GSX-R1300 Hayabusa 2014 SUZUKI GSX-R600 2014 SUZUKI GSX-R750 2015 SUZUKI GSX-R1000 2015 SUZUKI GSX-R1300 Hayabusa 2015 SUZUKI GSX-R600 2015 SUZUKI GSX-R750 2016 SUZUKI GSX-R1300 Hayabusa 2016 SUZUKI GSX-R600 2016 SUZUKI GSX-R750 2017 SUZUKI GSX-R1300 Hayabusa 2017 SUZUKI GSX-R600 2017 SUZUKI GSX-R750
