QUALITY head bearings recommendation
Discussion in '5th Generation 1998-2001' started by Lint, Aug 23, 2016.
  1. Terry Smith
    The length of the extended fork is determined by the engagement of the end of the fork tube and the bottom end of the top out spring. The top out Spring can be compressed by the main Spring and make the assembled fork longer. If your preload on the main springs is different the total length can be a bit different. Once it is all bolted together the fork behaves as a single assembly so it doesn't have any effect.
  2. Lint
    Lint Member
    Simi Valley, Ca.
    Yep!!! That is what's doing it on mine. My bolt on the bottom of the fork needed to be tighter and was seeping, but none of that caused the thunk. F'ing linked brakes...
  3. VF1000Fe
    VF1000Fe New Member
    Alberta
    All Balls Bearings are fine. They are just rebranded. Been putting them in bikes forever.
    They just need to be installed square and not damaged on Install, properly Lubed and adjusted.
    Note the wimpy Honda Gen1 Ball Bearing Race,,.. pathetic.
    If you got Ball Bearing Stem bearings, get them Out!
  4. dino71
    dino71 New Member
    New Jersey
    Has anyone ever purchased American made tapered bearing for their bike? If you did can you let us know what model numbers you bought to match the Chinese "All Balls"? If anyone happens to have a "All Balls" set perhaps you can share the numbers that are on the bearings. Does anyone know is seals can be reused?
