R/W/B fell over :(
Discussion in 'General VFR Discussions' started by buttonhook, Jul 15, 2009.
  1. buttonhook
    buttonhook New Member
    Maryville, TN (six miles from the dragon)
    I was told it wouldn't affect it because it wasn't my fault. However, I'm going to fix this one myself even though I have a zero deductible. FYI I just had to file a claim on my car also because of a flood also and it took 3 months to get back(went so far as the dealership put a dead bird under the hood) and what do you know a day after I got it back the tranny when out???....I need a break bad!!
    #41
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Well, "they" say it comes in threes. So I think that 2 bike tip-overs, a flooded car, and a bad transmission have used up all the bad joo-joo.
    Things are on there way up!!
    #42
  3. buttonhook
    you would think but.....a kid at the high school backed into my car crushing the door when I was on the way to take the car back to the dealer....and my wife dropped her ninja in the drive way and if you havn't read the post "I had to kill...." then you'll get a taste of it. On top of all of this I work full time, go to grad school full time and I have a family full time so I'm stresses alot!!!! and I just had hand surgery so I can't even try and ride to de-stress my life.
    #43
  4. TimRav
    TimRav New Member
    NE Ohio
    Jeez, buttonhook, if anyone ever needed a long weekend off it's def. you. :frown:
    #44
  5. mark123
    mark123 New Member
    Surrey B.C.Canada
    WHITE:thumbsup:
    #45
  6. NorcalBoy
    do something better than powdercoating your wheels with that extra money, buy yourself a good set of fork springs, some good fork fluid, and a good shock spring, at a minimum.....after that you can begin to polish the turd.
    #46
  7. motorhead1977
    motorhead1977 New Member
    Albany, NY
    Buttonhook, I too had a tip over - pulled hamstring as I came to a stop. Total damage - nil. I have frame sliders that I got from a fellow named Radar over at VFRD. They required cutting the lower fairing but with the mounting jig supplied it was really very easy. They mount at the upper engine mounting bolt, which is also supplied. Here is a pic of the "damage"
    Slider:
    Right side hard bag:
    Right side mirror scuff:
    The couple hundred for the sliders saved me a bundle on repairs. Now if only my leg was also as undamaged. Still healing up from that "event".
    #47
  8. buttonhook
    I have thought about the sliders but they would not have helped this time as the bike never hit the ground it fell over against the side of my building at about a 45 degree angle. They would not have stopped the first damge either as my bike hit my wifes ninja on the way down. Having said that they would have been very usful had the bike just fell over to the ground, but with my luck that just doesn't happen it seems.
    #48
  9. buttonhook
    ok I want to make sure I order the correct thing is the cowl stay (upper) 64500-mcw-k10 is that the metal tube structure that the mirrors bolt to? I think it is but I want to make sure
    #49
