Random photos
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Apr 1, 2024.
  1. sixdog
    Cook Bazz, COOK!
    Bazza likes this.
  2. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Finished the carbs last night and got a start on the fairing repairs.
    Cleaned out the main jets and replaced the low speed jets with brand new 40's. Also new float bowl gaskets. Neither set had any history of leaking so I did not replace the fuel tube o-rings. These will be for personal use so if they start to leak down the road no biggie, I will address at that time.
    One set of the main jets were almost completely clogged. Both of these carb sets should work really nicely.
    I have one more set to do - maybe at the end of the day. It's the one that had the rounded off screw holding the air box bottom on, which I still need to get resolved.
    In the meantime going to get the fairing work done.
    First this.....
    Then this........
    ........needs to look like this.....
    First a template......
  3. Bazza
    Bazza Member
    Fairing work went well. Set aside to get this 3rd set of carbs done. These needed a little more care so doing a bit deeper cleaning.
    Discovered a way to get the little washers and o-rings out of the pilot screw holes easier. Pipe cleaner!
    One of the float valve pins was very hard to remove - was bent! So replacing that. One of the pilot screw o-rings - the large one on the outside - was torn up too so gotta find one of those. And one of the pilot screws still had it's little cap still on it....weird!
    And the low speed jets didn't even have a size stamped on them. Being replaced anyway but again - weird!
    Diaphragms are all out and look OK.
    RogueRC24 likes this.
  4. RogueRC24
    The service manual will have the technique for removing the pilot screw cover. I found that info in my Hawk manual first. It is most likely in all of the service manuals.
    Got some work in this weekend Bazza! time for a beer!
    Bazza likes this.
  5. Bazza
    Bazza Member
    Thank you @RogueRC24 - it's in the V4 Dreams website as well. Just apply some heat and gently pull off.
    I decided to leave that part alone for now and am finishing everything else up.
    Yes - been a productive weekend so happy to get some of this in my rear view mirror!
    Tomorrow I get those 2 bikes going again at my storage units.... :)
    How's things going with your new ride?
  6. Bazza
    Bazza Member
    Looks like we're back!
    A huge thank you for all those who keep things humming here. :)
    I finished that last set of carbs today. Got the caps off the pilot screws....just apply some heat with a grill lighter and them pull off. Then you'll need to remove the stuff in the screw slot - I used a paring knife. Then set them at 2 1/2 turns out. All my rebuilt carb sets are labeled, wrapped in bubble wrap, and then bagged and kept inside the house for future use.
    I have another set that will need complete disassembly and cleaning but won't do anything with those for a little while. I need a break!
    I also got more fairing repair work done and also spent some time organizing some of my fairing fasteners. I have some set aside for the bikes I'm currently working on.
    I also pulled together a complete set of blinkers for the Cold Devil bike, which I expect to have on the road this week.
    Next up after getting the fuel tanks back on that one and the RWB tribute bike, will be clutch slave & front brakes for the Arizona F1. Hopefully the masters I have will work OK.
    I have to do some mowing tomorrow and some other stuff this week so going to be a busy one.
    Feels good to have the carbs out of the way and my kitchen back!
    RogueRC24 and sixdog like this.
  7. RogueRC24
    I need approval from my PT before I add load to my shoulder. I am excited to ride it. The short test ride was excellent. It has been babied. Everything is smooth and for a 600, fast. I suppose technically it has the most hp in the stable. Not sure my son will get to own it if I can still ride. Lol
    Bazza likes this.
  8. Bazza
    Bazza Member
    Excellent! I'm very happy for you. An early Christmas! :)
  9. Bazza
    Bazza Member
    Mowing done and home for lunch. Weather permitting will head to storage units.
    BTW - here is that rounded off screw on the air box housing. I ended up pulling the housing around back and forth to loosen the crew enough to remove. No real damage to the housing or plenum - Honda tough!
    The carb set also shown. They were a little rough but should work OK now.....
  10. Bazza
    Bazza Member
  11. Bazza
    Bazza Member
    Was able to get a quick strike mission in tonight and got the RWB tribute bike finished.
    Will take her out tomorrow for a test ride after I get the tires aired up.
    Tomorrow I do the same with the Cold Devil bike.
    TCB!
  12. Bazza
    Bazza Member
    Pretty good day at the salt mines today.
    Not a great start though as the front tire's tire stem on the RWB tribute bike started hissing after I aired it up so I parked it and went on to the Cold Devil special.
    Happy to report I now have it back up and running with a set of rebuilt carbs, new fuel lines, new tail fairing, and f. & r. turn signals.
    I also found a loose wire that may be the clutch diode culprit.
    It runs and rides incredible! Just have to finish the side fairings now.
    That Yoshi sounds killer! ;)
    Colddevil and Prime Target like this.
  13. Bazza
    Bazza Member
    Just finished the left side lower fairing that needed repairs.
    Down and dirty but should get the job done for now, which is all I want.
    Before:
    After:
  14. Bazza
    Bazza Member
    The other (right) side is in really good nick. Left one in this pic. That one on the right is aftermarket and I decided against using it.
    You will get a better view when I get them installed.
    Perhaps tomorrow.
  15. sixdog
    It’s looking pretty good Bazz
    Bazza likes this.
  16. Bazza
    Bazza Member
    Thanks, Six. It was a good day to work on the bikes today., weather wise.
    Feels good catching up! A LOT LOT LOT more to get done but enjoying the journey - and learning a LOT every session. Little things, ya know.
  17. squirrelman
    good work and good progress along a path many of us have traveled 902185173_Picture1-12-2020236.jpg.73919c3b7ba7309c5a1b07ea986d83ae.jpg
  18. RogueRC24
    Nice work Bazza! Your work rate is crazy right now! That Yosh..mmmmm
    Today was my first day riding since late March. Yeah!!
    Took out the kids Hawks and my new CBR. The CBR might as well be electric. It is ultra linear in sound, power, and pull. The previous owners took pretty nice care. I need to swap out tires, the front is ultra shot and luckily I have a brand new 180 rear Pirelli sitting in the garage. Not sure I can change the tire, but I will look into it in few weeks. Need to heal and strengthen more.
    sixdog and Bazza like this.
  19. Bazza
    Bazza Member
    Thank you, @squirrelman ! Respect! :)
    She's a nice addition to the quiver, @RogueRC24 - wow - so much awesome in that pic! Rest up and take it easy - you'll get there, my brother.... :)
    squirrelman and RogueRC24 like this.
    Pretty sure the F3 rear wheel is 5.0
    Not recommended for a 180. You need 5.5 for that. A 93-95 CBR900RR rear wheel is 5.5 and is/was a popular swap to run 180 tires. May need to modify spacers for alignment.
    Glad you're back on bikes. I was SO ready after my shoulder surgery.
