Random photos
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Apr 1, 2024.
  1. sixdog
    sixdog Insider
    Luckily it’s a small engine so easy to remove from frame. It’s awesome that plenty of us here can do the work ourselves… dying breed.
    Good luck Brother… I know it will come out better than new.
    Bazza likes this.
  2. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    I've never R&R'd a VFR engine but need to do so for one of my RC24's.
    Thinking I should have it up on a lift table to do so.
    My to-do list is not short - but will keep chipping away.
    I really should try to prioritize this one though.....
  3. Bazza
    Bazza Member
    Master innards. Top is the clutch. Bottom the front brake.
  4. Bazza
    Bazza Member
    bmart likes this.
  5. RogueRC24
    Brake master fastener?
  6. Bazza
    Bazza Member
    Correct! Sucker didn't want to come out....lol......
  7. Bazza
    Bazza Member
    Also saw my low fuel light come on today - so know that's working.......
    RogueRC24 and sixdog like this.
  8. Bazza
    Bazza Member
    All this work I've been doing with my fairings. I kept wondering why I didn't have a set for the RC24 in better nick. Then I got to thinking about the big Pit Bull box and when I took it out to my storage unit - I told myself this would be the perfect box to store fairings safely until needed.
    And as such, didn't I stash a pair in there that were near perfect?
    So it was on my to-do list today to check.....Bingo!
  9. RogueRC24
    Nice. I do the same. Our shop unwraps 60ft a day of the nice foam sheets from received material. Also have access to nice oversize boxes.
    Bazza likes this.
    I wouldn't recommend that. Once it is lowered, you need to tilt/roll it out of the chassis.
    If you have a condor type front stand, I would put in that and put the rear on a swingarm stand. Get the bike as high as possible while also secure. A rolling hydraulic car jack with and interface between the pad and the pan.
    Do all of your prep work on the lift of course, including getting all of the engine bolts loose, but when its time to lower the engine... Go to the the floor.
    Some help from somebody steadying the engine is recommended, cuz it will be kinda "balanced". But I have done it myself more than once.
    That's my advice.
    I now tend to strip the bike away as much as possible with the wheels off the ground and the oil pan on a solid crate. Wheels, forks, swingarm. Remove the rear stuff first and let the bike rock forward on the front tire. The when you remove the front wheel, the bike will balance out. Then remove forks.
    Then I lift the chassis with the wires harness off and over to the new engine. That is my old man method now.
    Bazza likes this.
  11. Bazza
    Bazza Member
    Thanks, Capt.....good to know. Funny I was just reading through the FSM procedure on this. And I watched a YT video yesterday - the guy was pretty funny but also I think I absorbed some stuff.
    It looks like a fair amount of work....especially for a rookie like me.
    When the time comes I will probably ask some questions ahead of time so would appreciate any additional input. Will be a little while yet.
    I've been fussing with replacing the tire stem on the front wheel of my red wheeled bike and looks like I will be removing the wheel, breaking the bead, and inserting the stem from inside. I do not see any other way around it. I've R&R'd front wheels before so just a little time and sweat equity involved, hopefully.
    Man it never ends......lol.....
  12. Bazza
    Bazza Member
    Pics later but I did get the front wheel off, the bead broken, and a new tire stem in. It's aired up to 29 lbs. and after I get cooled off am going to return and re-install the wheel.
    Hotter than Hades out.....especially when you're wrenching in a non-climate controlled environment......:(
  13. Bazza
    Bazza Member
    Decided to stay in for a while and get caught up on a few things here plus watch the World Cup game with Australia. In the meantime we got some decent rains so the temps dropped back down. I went over about an 1 1/2 ago and finished getting the wheel re-installed, so now thats done. I have a few more to do - but also noticed my fav. Blue bike - the one with the Yosh - has an inflation problem on it's front tire. That one has new tires so maybe another valve/tire stem? At any rate, it will probably necessitate the front wheel removal so I know the drill and will try to attack it next week.
    Nice!!
    Take the cap off and put some spit on the valve stem (see if it bubbles) just to make sure it's not just the core that is leaking.
    Looking good!
    Bazza likes this.
  15. Bazza
    Bazza Member
    Thank you - and great idea about checking the stem. If that turns out to be the issue I will owe you big time! :)
  16. Bazza
    Bazza Member
  17. Bazza
    Bazza Member
  18. Bazza
    Bazza Member
  19. Captain 80s
    Even a Ninja must hide from a Hurricane
    mello dude, Viffer J and Bazza like this.
  20. Bazza
    Bazza Member
    Just picked up a used Yosh on eBay and it arrived today. Needs a little love so I started by wire brushing off as much of the surface rust as I could on the pipes. It's now sitting in one of my brand new pails of ER.
    After I finish with the steel pipes, I will polish the muffler itself. Should turn out pretty good. I have the clamps sitting in a simple green solution.
    RogueRC24 likes this.
