Rattle knocking from front of motor - timing
Discussion in '6th Generation 2002-2013' started by NOLA VFR, May 8, 2009.
  1. NOLA VFR
    NOLA VFR New Member
    New Orleans
    Hello:
    I did not find anything on point searching so here is my issue/question:
    I pulled my bike into the garage after a short ride. Engine warmed up. I took my helmet off to put the bike away. Then I heard a rattle - seemed to be in some type of rhythm - knock, knock, knock - pause - knock, knock, knock. etc. I used the old rod “stethoscope” check putting an aluminum rod against the motor at different spots to try to isolate the sound. It seems to be from the front of the motor – right side. I’ve never been into one of these motors but it looks like the timing cover. Has anyone else had this experience on know what this might be?
  2. park800
    park800 New Member
    North Ga
    I have the identical bike but can't say I have ever heard that sound you are refering to. How many miles does yours have on it?
  3. NOLA VFR
    NOLA VFR New Member
    New Orleans
    I just turned 5000 miles. Today was the first time I've noticed the noise. Its relatively faint but noticable. You have to get down in the front right side to really hear it. Pressing the aluminum rod on my ear is how I really picked up the sound and figured out where it appears to be coming from.
  4. NOLA VFR
    NOLA VFR New Member
    New Orleans
    With only one reply to my question, I guess I'm bringing the bike to the dealer to have it checked. If there are an more thoughts please let me know.
  5. NOLA VFR
    NOLA VFR New Member
    New Orleans
    Well, i brought the bike to the dealer. It made the niose for one mechanic and then not for the second. They said that if something was wrong that it would be constant noise. I'm fmiliar with the valve rattle. This was different. Any ideas. I'd love to hear replies that it is normal....
  6. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Does it go away if you pull in the clutch lever, either in neutral or in gear?
  7. NOLA VFR
    NOLA VFR New Member
    New Orleans
    No, it continued with the clutch pulled in. I did not try it in gear. I'll give it a shot when I get home. It seemed to go away though before the second mechanic listened to it this morning. I'm pretty sure it comming from the front cam cover. I checked all around the motor with an aluminum rod against my ear. The cam cover seemed to be it.
  8. darionscard
    darionscard New Member
    Silicon Valley
    Please do post if you find out what this is. Mine's started to make a noise I'd initially expect to be a rod knock except that it doesn't always do it and it's not something that happens under load. I've tried the old 'hold the brake and give gas' method to verify it and it won't do it there. Also it seems to go away if the bike is moved from side to side. I've had days where it won't do it at all then days where it does it just from my 10 min ride to/from work. :confused:
  9. jmt256
    jmt256 New Member
    Sounds like you may have a bad cam chain tensioner. A similar noise on my old Kawasaki turned out to be just that. I'm no mechanical engineer but I believe the sound is caused by an under tensioned chain slapping against the valve cover the same way a loose drive chain can against slap the underside of the swing arm when you are running at light throttle/coasting. Do a search on the forum for cam chain tensioner replacement. Your mileage is much less than most people who encounter the problem (usually around 30,000) but then again, Honda V4 cam chain tensioners have been problematic for almost 30 years.
    Hope this helps
  10. dogman
    dogman New Member
    Adelaide Australia
    What oil are you running?
    I would try running a 10w40 semi synthetic, eg Mobil or Motul before I started to panic.
    I doubt it would be anything serious at your mileage.
  11. crustyrider
    crustyrider New Member
    North Country, New York
    not in the 86s no chain gear driven cams...... did they go back to chaind driven cams? if so what year?
  12. NorcalBoy
    Crusty...If you want to start a war, you don't do it by throwing firecrackers, you, of all people, should know this doctrine. :tongue: *End Threadjack*
  13. TOE CUTTER
    Clutch cover
    It may be worth pulling the clutch cover for an inpection. Had a noise as described and for what ever reason one on the bolts in the starter clutch had come unscrewed and was hitting the clutch cover.May be as simple as that.
  14. NOLA VFR
    NOLA VFR New Member
    New Orleans
    Thanks for the input. I actually started this thread months ago and the noise continues - no better, no worse.
    I'm bringing the bike to the shop next Tuesday - under warranty. I'll let ya'll know what they say.
  15. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    Ya mine makes some rattling / vibrations when i let the clutch out in neutral and goes away when i pull the clutch in. I always thought this was odd but i was told its normal on the VFR.
  16. NOLA VFR
    NOLA VFR New Member
    New Orleans
    THe sound does not change - clutch in or out. I dropped it off at the shop this morning. THe mechanic actually heard the noise before I left. I post the outcome.
  17. darionscard
    Silicon Valley
    any luck? What was the verdict? Bad tensioner?
  18. plasma
    plasma New Member
    Merseyside England
    It may be the flapper valve just under the tank at front of bike.
    Plasma.
  19. hootiehoo
    hootiehoo New Member
    arkansas
    what did they say at the shop?
    3000 miles and just started a ticking / clacking sound that keeps with the rpms seems louder with higher temps Ive only put about 5 miles on it after it started.... I need to get to work on it tomorrow?
  20. hootiehoo
    arkansas
    07 RWB 3200 miles on it
    so I took it to Honda the service manager came out to listen he said that it sounds fine ... I argued politely for a few minutes... and than it got a bit (wormed up) louder and he admitted to hearing it.
    So he grabbed the throttle and smashed it to red line and held it there 6-7 seconds until i went to grab for his hand and knock it off! (isn't bad to rap a bike out with no load on it?) , he said well if it did not blow up just now than its fine. Than tried to sell me heated grips wtf?
    What should I do it runs great but the ticking sound is getting annoying, it ruins the butter smooth sound I fell in love and enjoyed the first 3000 miles
    If I liked crap sounding bike I would have got a harley!
