Rear fender modification
Discussion in '5th Generation 1998-2001' started by storm, Feb 14, 2010.
  1. storm
    storm New Member
    Sherbrooke, Quebec
    Hello everyone, i got myself for my 40th a 5th gen VFR , love it !
    My quick question is: i got from eBay a fender eliminator bracket and i need to cut the original huge bulky ugly black fender. before doing this and talking to friends, one pointed out that if i remove it, since it goes down a lot , will the water reach the passenger (when i have one) or my luggage when on a camping trip or will the water stay out or arms way.
    Anyone did the modification with great results? Does the water from the turning wheel reaches the passenger?
    Before using my trusty Dremel ...know what i mean.
    many many thanks in advance !
    Storm
  2. kurupt
    kurupt New Member
    how about cutting the fender and adding a cool lookin tire hugger.
  3. Badbilly
    Kind of depends how much meat you take off the rear fender. I would be concerned about not only getting water and other stuff on your passenger and your luggage but caked on grunge around your battery box, wiring harnesses, tail light assemblys ect.
    Not sure but your rear fender is probably ABS plastic the same as the fairings. A Dremel may generate more heat that is wanted to cut this type plastic. Maybe a plastic cutting blade ( no offset pitch-lots of fine teeth) and cutting it manually might be better.To do precise cuts a trick is to apply masking tape to the area and draw your cut marks on the tape. Go slow or better, take the whole fender off the bike and brace the shit out of it before starting any plastic surgery.
  4. revguy
    revguy New Member
    North Bay Ontario
    I cut mine with a utility knife, I just kept scoring it over and cut mine off.....looks much better now, but havent had it out yet in any rain, also had to put a hugger in there too to finish it off .
  5. storm
    storm New Member
    Sherbrooke, Quebec
    I just did the modification on my VFR. simple yet good looking.
    before and after pics.
    good ol' Dremmer tool, time and patience, and a couple of beers to celebrate after
  6. vfr-treiber
    vfr-treiber New Member
    Hamburg
    hello storm,
    nice modification. havent you problems when you ride at bad weather conditions ?
    i think the passenger or the luggage will be wet and / dirty or muddy ?
    and yourself, do you stay dry - only after your modoifacations, when you ride at bad weather conditions ?
    kind regards
    VFR Treiber :cool:
  7. safetypro10
    safetypro10 New Member
    Dallas, TX
    What Storm said. Except I also painted the underfender to match the body and waxed it real good. Also use a hugger. Yes, when it rains I get SOME water thrown up, but not a lot.
    Looks so much better, and how often do you ride in the rain anyway?
    Larry
  8. vfr-treiber
    Hamburg
    in our area the rain is omnipresent !
    we have to look for it all time :wink:
    kind regards
    VFR Treibe r :cool:
  9. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    I've completely hacked mine off...made a custom bracket. Have not ridden in rain, but have not noticed any grunge on the taillight either...
  10. storm
    storm New Member
    Sherbrooke, Quebec
    i noticed some small "stains" or marks on the plate when i ran into some wet spots, but i rarely ride with a passenger.
    ANd for us too, rain is part of our riding summer haha
    i'll keep you posted about this issue.
    thanks
    btw it looks great "live" and the led lights at night... perfect.
  11. benrod800
    benrod800 New Member
    Everybody is mentioning putting on a hugger, does anyone have a particular hugger in mind? I did a google search and I was getting manufactures in England. Is there any in the US?
  12. VFRBenny
    VFRBenny New Member
    Oakland, Cal.
    My cut worked well, no water on me!
  13. kliner01
    kliner01 New Member
    Iowa
    I was fortunate enough to buy my 01 with a pyramid undertail installed
