rear shock White vs Ohlins vs Penske vs ?
Discussion in 'Mechanics Garage' started by reg71, Sep 28, 2007.
  1. fotomoto
    fotomoto New Member
    South Texas
    3 way is MUCH better than 2 way IMHO for those keeping score.
  2. Scott_Lilliott
    Scott_Lilliott New Member
    Massachusetts
    Another one to add to the mix:
    Hyperpro.
    Have it, love it, $850. with 3-way damping and adj. length.
    It uses a progressive spring rather than straight rate. Perfect for adding weight or track days. BTW, the shock is made by Wilbers, the spring is unique to Hyperpro. THE smoothest ride I've ever had.
    www.hyperprousa.com
    Scott
  3. RVFR
    Was able to get my WP from LE Engineering, as noted mine too was set up with the correct spring weight, seemed it was right around $685. Great folks to work with, couldn't be more pleased. I also went that route due in part LOL to be a wee different, that and it was a tad less than the Penske. Over in Europe WPs are right in line with Ohlins, so figure whats to be hurt, Great shock, full 3 way, thou must say since I've had it set up, I've never touched it. I also have the Race Tech Fork springs with shim stacked F3 valving in place, so yea My baby rails. Next, to see if F4i forks fit, they measure up saying they will. then I'll have even better brakes too.
  4. fotomoto
    fotomoto New Member
    South Texas
    Yes they do and you can upgrade them for even better braking than the F4i clampers:
  5. RVFR
    Nice, I knew I was on the right path, how's it look on the upper tree? as F4 forks are like 20mm shorter? I had it in mind to make one of clip on's that will make up the difference, that way the ride height can stay the same. not sure what happens other than initial thought tells me by letting her ride lower, quicken ups the steering with a loss of high speed stability.
  6. fotomoto
    fotomoto New Member
    South Texas
    Here's the good part: because the f4i has a steeper steering angle than the vfr(s), it's triples have more offset compared to the VFR. When mounted on the vfr, this slows the steering down at the standard VFR fork height so you will want to drop the triples (raise the forks) some to get back the quickness.
    This "should" give you enough fork tube height above the top triple to mount clipons. I say "should" because I run a superbike handlebar and haven't tried it.
  7. mello dude
    I went thru some simular gyrations - I considered Super Hawk forks and found them shorter - to make up the difference I used the stock 5th gen upper tubes that are a bit longer than the SH. A maybe is to use 6th gen uppers in F4i lowers (43mm) to make some length. I havent dug in to it - just an idea.
    My focus was the brake delink - forks were kinda an after thought and along for the ride.
    Good luck,
    MD
  8. reg71
    Sikeston, MO
    any word yet? also have you posted the chase video yet? I was wondering how it came out? I think you can upload it to the photo area and it'll run from the site...
  9. R.W.
    R.W. New Member
    Cloverdale CA.
    Still waiting to hear back from him, he just got back from the AMA Formula Extreme series, he should get back to me in the next day or two, as far as the video, none of it came out very good when the camera was mounted to the bike, the only part that was salvageable was the part I down loaded yesterday on the Road Trip thread, all of my camera and video will be upgraded by spring where this never happens again...
  10. mello dude
  11. mello dude
    - Just info - RC51 calipers are a strait up bolt on to the F4i too.
    Fotomoto - what calipers are those?
    MD
  12. emon07
    emon07 New Member
    Queens, NYC
    I have the Penske and also took my bike to GMD Computrack and had the raceteck gold kit installed and had the forks revalved for my weight and riding style. I still feel the Olins is the better choice for people who are track rats - three way and the track guys are all familar with setting up the Olins. I could use some rain gear but I am saving my money for the stainless steel Galfer kit which will be my final mod before getting my bike re-painted.. Can't go wrong with the Penske.
  13. reg71
    Sikeston, MO
    sounds like your mods are right in line with what I'm wanting to do also. I'm hopin to get most of them done soon to get back on the road... Im still waiting to hear from RW on whther he can get a good deal on the Penske... I haven't decided where I'm buying anything yet even...
  14. R.W.
    R.W. New Member
    Cloverdale CA.
    Talked to him this morning and he said the price would be $670.00 plus about 20.00 shipping to get it to everybody's house, it would be a little cheaper if a couple more riders bought in, Just need everybody's riding weight, if any VFRworld member wants one of these shocks, I'll pay the upfront cost as long as I'm reimbursed, this is a one time offer.
  15. fotomoto
    fotomoto New Member
    South Texas
    2001-2002 GSXR1000 6 piston with matching m/c. Bolt right on with only a couple of mm's of shimming with washers to center them on the rotors.
    Just ordered a set of ebc hh's for them last night as a matter of fact. I like the initial bite those offer over whatever came with these (I assume stock pads but don't know for sure).
  16. reg71
    Sikeston, MO
    sounds like we have a winner. I weigh 200# +/- depending on liquified barley intake.. just pm me or call me to work out the details... I'm ready now. ;) I also just got y2k mirrors and new side panel and front panel... Soon she's gonna look like a new lady. Got a lot of little carbon fiber doohickies, too.
  17. eddie cap
    eddie cap New Member
    Valley Forge, Pa
    Hey Reg 71, Just wondering what carbon fiber components that you have on your bike;maybe I am not looking in the right places,but have not seen much offered for the VFR's. Thanks eddie
  18. reg71
    Sikeston, MO
    mostly just the fake stuff. I just keep buying whatever ebay offers pretty much. Just tryin to accent a little bit. debating on the carbon fiber hugger (it's actually plastic also) but looks ok...
  19. elf800
    elf800 Banned
    dallas
    shock 4 cheap price
    canib can make u custom shock outta old truck spring lol go to canib custom whiskey parts top quality for nearly no value lmfao........
  20. Belo
    Belo New Member
    Hungary
    Hi!
    Please tell me the spring rate do you have in your Öhlins rear shock and how much kg/lbs are you!
    Thanks!
    My weight ~225 lbs in full gear. My handler can't tell me the proper spring rate in this case. Therefore I chose the S46HR1C1LS with 180 N/mm spring rate, because 170 N/mm is the dafault spring rate.
    Sorry for my english
