Rear Shock
Discussion in 'Europe' started by nocross, Nov 5, 2015.
  1. nocross
    nocross New Member
    The rear shock / damper on my 1999 VFR 800 is failing. I've managed to get hold of one from an early VTECH model. Are the the same part?
  2. OOTV
    OOTV Member
    They are not, the 6 Gen is shorter. You can shim the shock by putting washers on top the upper mount below the frame. I believe 5mm is the length difference and that would get you back to stock height.
  3. nocross
    nocross New Member
    Thanks thats been of great help.
