Replacement Stator for 94 VFR
Discussion in 'General VFR Discussions' started by ABVFR, Feb 3, 2020.
  1. ABVFR
    ABVFR New Member
    Well, no start today; more electrical gremlins, although the battery appears good. I'm guessing another fried oem R/R. This is the 4th oem R/R (plus 1 from Ricks) over the life of the bike. I already have the VFRness, connectors look good, and now think I should replace the (original) stator (40k miles), and get a fh020aa R/R super kit from roadstercycle.com. But it appears an OEM stator is n/a. What is the best alternative stator?
    Thanks!
    AB
  2. Thumbs
    Thumbs Member
    Bath(ish)
    There’s plenty on offer if you do a search
  3. bk94si
    bk94si Member
    I bought a Rick's stator for mine.
  4. squirrelman
    Picture1-12-2020 031.jpg be sure to inspect the red plug atop the starter relay for signs of melting as that will reduce charging voltage.
  5. Cogswell
    Cogswell New Member
    Try Custom Rewind in Alabama. They did a great job on my 6th gen stator - just a bit over $100. Send them your core and they send it back refurbished. You should be able to find them on Facebook. Also, check out Roadster Cycle for upgraded R/R - bypass the crap OEM wiring and get a better unit than OEM. I'm in that process now.
