reproduction 86 vfr tail section?
Discussion in '1st & 2nd Generation 1983-1989' started by VFR750Moose, Nov 7, 2013.
  1. halo7
    halo7 New Member
    Vancouver, Canada
    I repaired a crack and the bolt-loops on my tail section with a kit from plastex. See: http://plastex.net/Product_Info.php - it comes with molding "putty" that you heat-treat and form around the piece you want to replace.
    They are holding up thus far. I can post pics if you want.
  2. VFR750Moose
    VFR750Moose New Member
    Any pics you can post will be greatly appreciated! Thanks!
  3. halo7
    halo7 New Member
    Vancouver, Canada
    Sorry if the repair isn't easy to see clearly. The clearer plastic is the repair. I have completely rebuilt the loops. It's holding fine.
    It's difficult to get the rubber mounting grommets in and out of the loops so I just took the pics from where they were installed.
    The other repaired section still needs to be sanded and repainted. It's ugly but the plastic weld is strong.
  4. BluRoad
    BluRoad New Member
    Antioch, IL
    That looks awesome. Nice work!
    JOE in IL
