Resetting ABS Code on 2007 model
Discussion in 'Mechanics Garage' started by upsscott, Mar 9, 2011.
  1. upsscott
    upsscott New Member
    Replaced the tire on my 2007 and switched the rotors by mistake. Caused the ABS system to go out due to the sensor ring not being present when I moved out the first time. Removed the rotors and placed them on the right sides. It hasn't reset itself and is still blinking while moving. Do any of you know how to reset the system without giving the stealership $100.00 to do it? Thanks.
  2. TOE CUTTER
    Have you tried disconnecting the battery for a few minutes?
  3. upsscott
    upsscott New Member
    No, But I will try that this evening.
    I am open to any other advice as well.
    A list to troubleshoot until one works is great!!
  4. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Here is a picture of the page which tells you how to reset the ABS light, hope this helps
  5. Metallican525
    Rockville, Maryland
  6. upsscott
    upsscott New Member
    Thanks!!!!
    Exactly what I went looking for.
