Restoring '99 5th gen
Discussion in '5th Generation 1998-2001' started by I0seb, Jan 14, 2017.
  1. RVFR
    Nice, is that an Ohlins?
    #41
  2. I0seb
    I0seb New Member
    Victoria
    Showa, off the 929rr.
    #42
  3. I0seb
    I0seb New Member
    Victoria
    Moved her inside and started the disassembly process, old shock is out so time to start looking for someone to fab up the new one.
    Those headers are definitely going to need coating :disturbed:
    #43
  4. I0seb
    I0seb New Member
    Victoria
    Shock adapter has been completed, test fitted it with no issues :glee:
    Glue is setting overnight, should be good to go tomorrow!
    #44
  5. I0seb
    I0seb New Member
    Victoria
    Spent the day cleaning the exhaust, took me about 3 hours with an electric drill, wire brush and sandpaper to get it to an acceptable state for painting.
    Did 5 coats of black VHT paint and baked it on the bike, looks far better than the sorry state it was in previously.
    Also fitted the shock, all worked perfectly :thumbsup:
    Shock fitted
    Now it's time to decide on the fork upgrade and what colour to paint it...
    #45
  6. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    Hi mate.
    It looks like you fitted the 929 shock as you found it with the original 15kg/mm spring/valving.
    I have it on mine and fitted a 21kg/mm spring with all the valving to suit and it is right on the money for my 74kg weight.
    The VFR is a heavier bike and has a lot more weight on the rear wheel (doesn't load the front as much) than the 929, it also has different rate linkages.
    You would be better off getting the whole thing redone to suit the bike.
    Ignore my post if you are doing it.
    #46
  7. I0seb
    I0seb New Member
    Victoria
    Yeah I'll be getting the suspension re adjusted once I've got the replacement forks, figured I'll just wait until I've got the full set, bike isn't going anywhere atm :p
    #47
  8. I0seb
    I0seb New Member
    Victoria
    #48
