Restoring a YELLOW '87 VFR700F2H
Discussion in '1st & 2nd Generation 1983-1989' started by Bazza, Nov 25, 2023.
    It should have IMMEDIATELY started bubbling.
    I make a cork stopper for the fill hole and suspend a bent piece of steel rod thru it. Down, and back into the tank, but not touching. Add a vent hole in the cork cap. I make my main hole a bit off the side to make sure I have room for the vent hole.
    Positive to the steel rod, negative somewhere that has exposed steel on the tank. Typically near the rear mount.
    It immediately bubbles like a school science project.
    Check and clean off the anode every now and then. And like I said, change out the solution. It's cheap to make.
    #41
    Bazza likes this.
  2. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    That sounds a lot easier than the way I'm doing it.
    Thanks......gonna work on it today.......
    #42
    And for some reason, my best results have been charger > battery > anode. I don't know why, maybe I'm imagining it.
    #43
  4. Bazza
    Bazza Member
    I read that is the method to use when you have a Smart charger. Mine is analog so should be OK, but good to know.....
    #44
  5. Bazza
    Bazza Member
    Lot of info online. Like this one........
    #45
    You might be surprised how fast the anode degrades after periodically cleaning it off. I would go with something thicker than a coat hanger.
    #46
  7. Bazza
    Bazza Member
    A piece of rebar would be good. That isn't coated. I'll have to look around.....
    #47
    I knew not to try and use just a smart charger.
    #48
  9. Bazza
    Bazza Member
    Maybe stick a piece of plastic on the bottom of the anode so it can rest on the bottom of the tank.......
    #49
  10. Bazza
    Bazza Member
    I know I was just repeating what I read...:)
    #50
    Not a bad insurance policy I suppose.
    #51
  12. Bazza
    Bazza Member
    OK - I like this method better. No sign of bubbles yet. My rebar probably has too much rust on it. I'll work on it more tomorrow and start off with a fresh piece of metal.
    I also need to work on a better positive attachment method.
    I had it attached to the lip first and then screwed in one of the fasteners and moved it to that.
    #52
  13. Bazza
    Bazza Member
    oops....just realized I have the polarity wrong........
    I just swapped them so we'll see........
    #53
    Scrape off some paint around the rear tank mount and attach the ground there. That way it is def not in contact with the solution.
    #54
  15. Bazza
    Bazza Member
    Guess I was trying not to do that to save some of the re-painting work but it makes more sense to do it so I will - thanks, Capt!
    #55
    Repainting? It will be under the rubber mount and under the seat. Just throw on some touch up paint of any color.
    #56
    Bazza likes this.
  17. RogueRC24
    I watched a video the other day about this. I need to do it to my Yamaha proj. He used a spray can lid with a hole for the anode and 1 for venting.
    #57
    Bazza likes this.
  18. Bazza
    Bazza Member
    I think I discovered my problem. The charger I was using must be a 'smart' charger in disguise......
    So I hooked up an old Sears charger that belonged to my grandfather and blam......instant results!
    All kinds of bubbling, sparks when I attach the clamps :), and have already gone through quite a few sacrificial anodes. Right now I'm just using some vegetable can sections I cut out with my tin snips.
    Will post more pics tomorrow but stoked to finally get things going......
    #58
  19. squirrelman
    could the system be powered by a car battery ?
    #59
  20. Bazza
    Bazza Member
    Yes.
    #60
