Restoring a YELLOW '87 VFR700F2H
Discussion in '1st & 2nd Generation 1983-1989' started by Bazza, Nov 25, 2023.
  1. bmart
    bmart Member
    Charlotte, NC
    Is there a single place with a clear and complete write up? I have all winter. I'm just a pansy.
    #81
  2. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Post #72 on the previous page has a You Tube video that takes you through it........
    #82
    bmart likes this.
  3. bmart
    bmart Member
    Charlotte, NC
    Just rewatched. Any advice on what else to remove from the tank? The filler/cap seems like a good choice, How about on the bottom. I don't think that I've had the tank off of either of these VFRS...or any of my FI bikes, only low/no pressure ones.
    #83
  4. Bazza
    Bazza Member
    Remember you're going to be filling the tank with water plus carbonate soda solution, so you don't want any openings except the top, where you'll be sticking the anode in.
    At some point though, you'll want to empty out the tank, flush with water, rinse out as much as possible. When you do that, it will be helpful to remove the bottom plate that holds the fuel sender.
    This pertains to the VFR tank I'm using here ('86-'87 RC26) but others too, I'm sure.
    The idea is to shoot as much water through it as possible to help wash out any debris loosened by the electrolysis.
    Hope this helps......
    #84
  5. bmart
    bmart Member
    Charlotte, NC
    Thanks. So, it will not harm whatever else in in there? I don't know if there's a filter or other devices/switches/pumps. And...do I need a battery or only the charger? I gave away all of my regular chargers in 2023. Maybe my neighbor will let me borrow it back. :) And only a car battery, or is a bike battery fine?
    #85
  6. Bazza
    Bazza Member
    Correct on the 1st question.
    Motorcycle battery should work fine along with a charger to keep it charged.
    #86
    Do not do it with the fuel pump or sender in place. You would want to make a block off plate or find an old sender base to use.
    If you provide some measurements of the plate, it might be common to other bikes and may help find a donor.
    I use a medium sized motorcycle battery with a Battery Tender connected no problem.
    #87
  8. Bazza
    Bazza Member
    Just finished up on the Yellow tank and now have the Blue one from the RC15 going with the electrolysis.
    I used my new endoscope to "look around" inside the Yellow tank before deciding it was good enough to dry with hair dryer and then spray down with the fogging oil, which I did. I set it aside for now and will proceed with other items.
    No doubt, the tank would benefit from some more work. I'm thinking the technique of throwing in some fish tank gravel and acetone and swishing around would be the next step, but with my recent hand surgery, I'm not going to do that for a while.
    I need to work on my endoscope skills but I think it did what I wanted today.
    BTW...this is the one I bought (Amazon $49.99):
    Endoscope Camera with Light, Inspection Camera with 5" IPS Screen, Endoscope with 32GB TF Card, 16.4ft Semi-Rigid Cable Borescope with Dual Lens, IP67 Waterproof LED Lights, Hardshell Case (Orange)
    Here are a few shots.......
    #88
    But some cheap nuts... And count them going in. Stainless sounds like a good idea, but stick to cheap so you can use a magnet.
    Don't use chain, rocks or gravel.
    #89
    Bazza likes this.
  10. Bazza
    Bazza Member
    Thanks! I've never used this technique before.
    Saw a guy on YT use the aquarium gravel and acetone and it really worked well, is why I said that.
    I also noticed some of these tanks are different in how the openings are formed which would have an impact on being about to remove whatever is put into them.
    Also saw some comments about using a cement mixer to do the "shaking" but there's probably other creative methods.....and I'm not even sure it'd be worth the effort.
    Too bad you can't just stick a long nylon bristled scrubber in there and let her rip!
    #90
    I know people that have bought old used dryers and disabled the heat element. Then super wrap the tank and stuff the drum so it doesn't bounce around.
    But those are tanks that don't have any internal plumbing.
    #91
  12. Bazza
    Bazza Member
    Wow....that's crazy.......
    I was thinking more along the lines of using an old bicycle wheel attached to a 4x4. Use some kind of strapping or hammock-like setup to hold the tank. And a big old crank on it to turn by hand.
    My overall goal would be to have something to take the weight off - not to do the turning part.
    And what if the wheel could be rotated in different planes too.....hmmm......
    #92
  13. rc24dk
    rc24dk New Member
    Denmark
    #93
    Bazza and bmart like this.
  14. Bazza
    Bazza Member
    Nice score yesterday that will help with the restoration of this bike. Crazy that these show up in the same Yellow color as my first bike! Fuel tank is almost perfect (2 tiny paint chips) and has been coated inside but looks like a good job. It also came with 2 Honda brand keys. The lower panels are aftermarket. The nose piece also with non-OEM blinkers. Everything else is OEM. Also came with a brand new windscreen not shown. Unicorns.......
    IMG_4708.JPG IMG_4714.JPG IMG_4723.JPG IMG_4724.JPG IMG_4725.JPG IMG_4722.JPG IMG_4727.JPG IMG_4728.JPG IMG_4731.JPG IMG_4729.JPG
    #94
    tsmitty and sixdog like this.
  15. Bazza
    Bazza Member
    Not quite ready to begin restoration of her yet.....but got the brakes off yesterday so I can roll her around easier now.
    This bike is gonna need a lot of help!
    #95
    tsmitty and bmart like this.
  16. sixdog
    Looks like fun Bazz... we have seen MUCH worse.
    #96
    Bazza likes this.
  17. Bazza
    Bazza Member
    Thanks, Six......I'm looking forward to the restoration. Lot of cosmetic help needed on this one! Engine should be fine....
    I have another 87 too in Blue that will need some work and am anxious to get to that one too, before more time goes by.
    #97
  18. tsmitty
    tsmitty Member
    Ohio
    Looks fun Bazza, the plastic pieces look amazing.
    #98
    Bazza likes this.
  19. Bazza
    Bazza Member
    Thanks, Tom....you ain't lying, brother! :D I'm still pinching myself to make sure I didn't dream getting those goodies!
    Today I removed the mirrors, blinkers, front headlight fairing, rear tail fairing, and the front fender.
    I had to drill out the two bottom fasteners on the inner fills but fortunately didn't muck anything up.
    The stuff I took off today is in really fantastic condition! :)
    I'll bring the color back on those fills using the same technique as Joe of V4 Dreams did here:
    https://v4dreams.com/shop-blog/archives/01-2024
    Even the gaskets for the front blinkers look great!
    #99
    tsmitty and Captain 80s like this.
    Nice grab on those parts!
    Bazza likes this.
