Rode Hard & Hung Up Wet: My 1986 VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by Mind_Surfer, Sep 13, 2011.
  1. smoke4ndmears
    smoke4ndmears New Member
    Maryland
    If you are twidgety you can disassemble the switch and clean/rebuild it to make it work. Did it with mine.
    OK, he is a cheap , impecuious bodger like me, and i've had similar sucess, but a wise man would just buy a new unit. Someone needs neurosurgical surgical control to fix that shit. Small muscle control. F* it Bunky, just buy a new one ! The shit i've taken apart and repaired wasn't worth the time it took.
  3. Mind_Surfer
    Mind_Surfer New Member
    VA
    Well, the local dealer had the brake switch in stock, for $20USD.
    Then the same thing as last year, had it running great, left it alone for a couple days, now nothing...pulled & cleaned the carbs again, still nothing. Next I will pull the coil packs to see if they check out...
  4. Mind_Surfer
    VA
    I seem to have fuel & spark, but the engine just won't start, just a sputter or backfire.
  5. Mind_Surfer
    VA
    Still nothing new...just a poot-poot-poot when you turn it over. Like it kind of wants to start, but nada. It seems weird to me, to run so well, then turn the key off, come back a day or two later, AND NOTHING. Well, maybe next year. Best wishes everyone.
  6. Mind_Surfer
    VA
    Hello friends, I am thinking of buying a battery, as the new one I had way back when I started this thread, died shortly thereafter. Without a battery, I have not even been able to find out why the motorcycle mysteriously stopped running. I don't really know what to do other than gamble the sixty bucks and give it a go. To reiterate, I had the motorcycle running great, with cleaned carburetors, all new fluids, brakes, and battery. All I needed was tags, insurance, and state inspection. Needed a front brake switch for inspection, went to dealer, returned with part, motorcycle has not run since. Drained all fuel at that point.
  7. thx1138
    thx1138 New Member
    Perth
    I say throw caution to the winds and buy the battery.
    Life's too short to stress over trivia.
    As the Y or Z generation says "YOLO".
    Also buy a good 8 stage battery charger like a ctek MXS5.0 and get a few extra years out of all your batteries.
  8. sunofwolf
    sunofwolf New Member
    I thought you were ring in the rain, I wonder where is the sliders? why don't people use them if you fall down more than I did like maybe five times, saved the bike all ready-but what do I know-sliders work. I don't fall down any more because I setup it up better than the factory stuff:spider:
  9. rhoderage
    rhoderage New Member
    Nova Scotia
    Buy battery. Install battery. Try to start. Post results.
    We will get it running :)
  10. Mind_Surfer
    VA
    I will pick one up this week, and let you know what happens!
  11. thx1138
    thx1138 New Member
    Perth
    Good luck. I hope it fires up.
    Remember that fresh high octane petrol is your friend for starting the bike.
  12. Mind_Surfer
    VA
    It fired right up! But there came a fuel leak I believe from the carb bowl area. I must have jacked up one of the gaskets...
  13. thx1138
    thx1138 New Member
    Perth
    Maybe leak due to dried out oring.
    Good sign it started though.
  14. Mind_Surfer
    VA
    I got the carb bowls resealed pretty well, but engine is not running on all four.
  15. bikebook
    bikebook Banned
    269 Bernard Avenue Kelowna BC
    Hello Guys!!!
    Great News for the Motorcycle lovers all over the world, Bikebook.com is launching the worlds first social network / online buy and sell for Motorcycle Enthusiasts. Signup today for FREE and show off your passion for Motorcycles! Bikebook.com has built this site for motorbike lovers and value your feedback.
    Visit BikeBook and meet all the awesome motorcycle lovers around you.
  16. thx1138
    thx1138 New Member
    Perth
    Bike book, I think commercial advertising is unwelcome in people's threads.
    You have now contaminated four threads with this. Show some manners and delete the advertising.
  17. bikebook
    bikebook Banned
    I was just trying to let people know about the site" Will delete them right away.
    No worries
  18. Mind_Surfer
    VA
    The spark looks OK, and after getting the engine to "idle" for a few seconds, I took temperature readings with IR thermometer on the exhaust ports. Definitely only firing the RF and LR cylinders. There is spark though.
  19. Mind_Surfer
    VA
    OK I'm getting back on this as soon as I obtain some -041 Viton o rings. Carbs coming back out for the umpteenth time, jets and whatnot going back in the cleaning bucket, and will check with fine gauge wire afterwards. Going to carefully remove the main fuel lines back to the wye, adding in two inline filters and new line. Guess I should remove the pilot jets this time, but I am not sure if I am supposed to or not, although it is mentioned in the manual.
  20. Mind_Surfer
    VA
