Rogue's NC30 Project
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Aug 24, 2023.
    Everything's cool there. Keep looking.
    RogueRC24 likes this.
  2. RogueRC24
    And now we have some solid connections. I have to put the fairing back on to test since the front signals are mounted on the bodywork, but hopefully this will remedy the running lights. I think my measurements were a little off, but this should do. image.jpg image.jpg image.jpg
    tsmitty and Fastdruid like this.
  3. RogueRC24
    Success, sort of. Apparently what ever I did to pop the fuse also killed one of the two bulbs. 12v-1.7w. Sheesh. image.jpg
  4. RogueRC24
    image.jpg image.jpg First fit up in months for the tail. Hard mounting the seat made me nervous, but everything lined right up! Soooooo stoked! Even my passenger seat release lined up. Still waiting on rear MC parts and we hit the road!
    tsmitty and Captain 80s like this.
  5. RogueRC24
    Cool gift from my son in Japan, before leaves for the US. NC30 headlights, RVF manual securely packaged with our favorite treats from Japan. image.jpg
  6. squirrelman
    in my expert opinion, it looks like possible rodent damage on wires due the innate propensity to chew upon things like insulation. common in some areas during long sitting.
  7. squirrelman
    just one idea: delete the crude worm-drive hose clamp {its gross}from the fluid reservoir line, and find something slicker, more hi-tech.
  8. RogueRC24
    image.jpg Upon SM request, a cleaner locking method. New kit installed in original master. Bingo, I can now torque the wheel nut to 87ft lbs using the brake. Yeww! Not that it won’t be covered up by bodywork, but a prime example of powder coating issues (threads above coolant hose).
  9. squirrelman
    :thumbs:
  10. NorcalBoy
    Did you give it to them with a bolt threaded in there?
    Nice. Keep an eye on that, you might need to switch to something with a little more clamping surface and pressure, but still better looking than a hose clamp.
  12. squirrelman
    ^^ sorry capt cheap simple stock shit like that common item NOT ok on this bike. maybe someone can find a colorfully-anodised AN fitting for a touch of class ?
  13. RogueRC24
    nah, because on the VFR750 they coated over the bolt and upon removal it removed way more then just the threaded area. Can’t win either way so I just tap and file everything before final install. PITA, But I am way more choosy about what I get done by them. Even with that buildup, this frame came out way better than the 750 as well.
  14. RogueRC24
    I will have to check my favorite AN site. Maybe they have something SM.
    SM, just so it's clear in the future, according to your "thumbs up",
    cheap simple stock shit like this common item IS ok on this bike, and is slick and hi-tech?
    Buy 2 clamps. Maybe you can find a colorfully-anodised version of this common stock item for the top of the tube, instead of just a cap to keep nasty brake fluid in its place.
  17. NorcalBoy
  18. NorcalBoy
    In some situations it is best to go clean and simple. You can't use an AN fitting there, unless you wanna do a whole lot of fucking around to make an adapter that fits the master cylinder. Not worth it, as it's mostly hidden by the heel guard anyway.
  19. RogueRC24
    I would love to have some stock of these guys.
  20. squirrelman
    thats ok but not pretty, at least its not obtrusive.
