Rogue's NC30 Project
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Aug 24, 2023.
  1. RogueRC24
    Finally got to use everyone else’s method for brake piston removal. Sooo much easier, since one of these was seized completely. Thanks forums peeps! image.jpg
    Gnarly.
  3. bmart
    bmart Member
    Charlotte, NC
    Compressed air?
    I think hydraulics still hooked up. bmart, the old crusty, nasty shit we work on laughs at compressed air. I have an old master cylinder mounted to a tube that I keep bled just for this type of scenario. Either I forgot to fucking pump them almost all the way out when the brakes were still operational on the bike or the brake system was so fucked getting a bleed to pump them out was futile. Or a 3rd scenario, I bought some used calipers that compressed air won't touch. I think being in that last example so many times is why I finally set up a spare master.
  5. squirrelman
    another possibile method uses a pressurized grease gun to force pistons out.
    Yeah I've seen that one. I rather clean brake fluid out of the caliper than grease.
  7. RogueRC24
    Sorry I should have defined what I was doing. I reattached the rear brakes master to the caliper and used the foot level to hydraulically push out the stuck pistons. One was moving more so I placed the pad and tool to keep the “loose” piston from coming out. Worked really well.
    I am pretty sure air would not have worked. When I end up with a spare master I will make a set up similar to Capt.
    Fastdruid likes this.
  8. RogueRC24
    - caliper stripped, rear pegs removed and everything vapor honed. Just need to buy the all of the brake lines and caliper seals. Found NOS rear pads for $10 shipped on Croober. My son is collecting parts and sending them from Japan on Monday. image.jpg 05CED58F-B6BD-4028-8928-4869DB2C7821.jpeg
    tsmitty likes this.
  9. NorcalBoy
    RogueRC24 likes this.
  10. RogueRC24
    ^ whoa, those are fancy.
  11. RogueRC24
    Yew, got my Rick Oliver fork Uprate kit just before my holiday break! Good timing. I will taking the forks all the way down, so expect questions. lol 2023-12-21 13.04.20.jpg
    Captain 80s and tsmitty like this.
  12. NorcalBoy
    Good, budget minded, choice.
  13. RogueRC24
    Before I reset the bike on the stand I wanted to finish right hand rear set area. Although I don’t have a brake line yet I am testing the layout for reservoir hose. The OEM tube and reservoir are toast so I am going with the poor man’s HRC kit.
    Still debating on OEM coolant tank or my Tyga reserve tank kit. Since the NC35 is pimped out with aftermarket, I want to keep this stock, but I can’t get the tank to look any better. Thoughts are welcome.
  14. RogueRC24
    Also hard at work on an Nissan GTP model from France with no instructions and a terrible painter. Hahahaha 5C6FD97F-3300-4CE1-B6CE-0372F5803275.jpeg
    Jim McCulloch likes this.
    I've bleached some back to a more acceptable color (92 VFR). I've also just painted some BAD ones black with Krylon Fusion that I didn't need to see "thru" them for fluid height, but were kinda visible with the bodywork on. Easy to just pop the cap and look inside every now and then. It's not like I'm doing a pre-ride 100 point inspection every time.
  16. RogueRC24
    ^ that looks clean. I like it. Hmmm,
  17. bmart
    bmart Member
    Charlotte, NC
    You just want a reservoir? i's just run a length of tubing blocked at the end.
  18. NorcalBoy
    RogueRC24 and tsmitty like this.
  19. bmart
    bmart Member
    Charlotte, NC
    Nevermind. I thought you were typing about brakes, not coolant.
  20. RogueRC24
    Yeah, that is my home made HRC kit. Lol
