Rogue's VF500 rebuild or part out!!
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Nov 17, 2022.
  1. Pdeano65
    Pdeano65 New Member
    Chicago
    Nice work! If you want to sell the rubber boot off your blown shock I would be interested. Mine is missing so I made one out of a rubber glove. Not ideal.
  2. Pdeano65
    Pdeano65 New Member
    Chicago
    Sorry so slow. I've been off for a while. Back at it. That's the new glass installed in the photo I posted a while ago. Here it is again if it helps.
  3. RogueRC24
  4. Pdeano65
    Pdeano65 New Member
    Chicago
  5. RogueRC24
    I will try and figure out how to remove the boot today. If you just want to pay shipping, I got chew!
  6. Pdeano65
    Pdeano65 New Member
    Chicago
    Wow! That would Awesome! More than happy to!
  7. RogueRC24
    Forgot to include photo of SuperTrapps mounted.
    Wheezy, devil_lish and bmart like this.
  8. straycat
    looks great !!
  9. sixdog
    sixdog Insider
    There is one on Iconicmotorbikes auction… not too clean though , yours looks MUCH nicer
    RogueRC24 likes this.
  10. RogueRC24
    I was scoping that one. It looks like the SD life added some corrosion. It also sounds like a valve tick going on. With some love it could be pretty dang sweet. I am interested to what it goes for since originally I was going to sell mine. My wife says don't sell what you might regret. :)
  11. sixdog
    sixdog Insider
    Your wife is correct !
  12. RogueRC24
    Well, my son is getting out of the Navy next year so maybe it would be a good hand me down for commuting. ;)
    The chin fairing has turned out to be pretty elusive. Never seems to want to stay installed.
  14. sixdog
    sixdog Insider
    Right?! It’s a chindemic
  15. RogueRC24
    Happy chin police.
    rc24dk and jstehman like this.
    Yes.
  17. sixdog
    sixdog Insider
    ‘Bout time
  18. RogueRC24
    So the front master on each the clutch and front brakes won't seem to pressure up as well as they should. Recommendations for rebuild kits.
    Just can't get any pressure on the front brakes. Lever almost to the bar. I know the pads are old, but I would expect better pressure from a newer master. Maybe it is a combo of shite pads and poor master function?
    Clutch is ok, but does not seem to want to pull the clutch pack apart all the way when lever is fully pulled. Makes getting in and out of gear a little difficult. I did pull the rod out of the case while cleaning, but then just placed it back in there. I didn't have any issue when I did that to my 750.
    Thoughts are welcome, but it would seem a rebuild is in order on each to me. I have never done a master rebuild either.
  19. squirrelman
    the mc [brake or clutch] needs to be bled first and hold pressure before the system can be bled.
    The front hoses are toast. And if you moved the pads around at all they need to find their new "home" and the feel will improve with some miles. Also the hoses are toast.
    How does the brass bush in the clutch lever look?
