Rogue's VF500 rebuild or part out!!
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Nov 17, 2022.
  1. RogueRC24
    ^^SM so I bled the top line connection at the MC first. Is there another way that I should bleed the MC?
    ^^ Capt, the lines are indeed toast, but I fear years of fork leak may have sullied the pads. I have completed 18miles on 2 occasions so I will bleed again this weekend and see if there is any improvement.
    I will need to take apart and check brass jimmy.
    SS lines and pads may be on order soon.
  2. sixdog
    sixdog Insider
    Just a thought… did you replace the crush washers ?
    Contaminated pads don't result in mushy lever feel. But yes, you probably have both issues.
  4. RogueRC24
    ^^6 - Crush washers... I think I reuse. Thinking they could bleed a little air? I need to really look into supplies so nothing is missed in the future. I think I will just order up the SS lines anyway, that will solve issues. I will also check out the MC and see if I missed something.
    thanks dudes!
