Rogue's VF500 rebuild or part out!!
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Nov 17, 2022.
  1. RogueRC24
    DONE. valves have been adjusted using the duel gauge method. .006” all around. Clean up and button up.
    I have seen videos and other posts with various measurements. Here is what I have on board right now. I think .006” must be the spec. These are all in that neighborhood. Gonna stop by the hardware store and look for a 3mm square socket before I attempt to adjust. Thanks ColdD for the yeeew toob vid.
    #61
  2. RogueRC24
    image.jpg 7391F452-6894-4D64-B49A-B365309DD89F.jpeg 18F14318-4B6C-44FC-A442-F28EBD383986.jpeg AC5A4D08-5872-413B-8177-23B210D99EAF.jpeg Update! So many little things complete.
    Carbs installed
    Radiator installed
    Foot peg brackets powder coated and installed
    Shitty rattle can removed from OE muffles and installed
    Rear end detailed
    one question, I killed the little breather separator s I am running tubing direct from crank case to air box. Anyone see a problem with this? I placed my drivers to highlight end to connection
    #62
    Wheezy likes this.
  3. RogueRC24
    #63
    rc24dk and Wheezy like this.
  4. Wheezy
    Wheezy New Member
    Loving your work!
    #64
  5. Colddevil
    Colddevil Member
    Wisconsin
    Looking clean man!
    I don't think removing the breather/collector is going to make too much of a difference--but that's a guess I can't back--hopefully someone else can give you some good advice. I'm fairly certain I've worked on several bikes that have nothing similar, but maybe there's different air box designs. I know I collect very little gunk at all when I open that little exit cap up at the end of the season.
    #65
    The only thing I can think of is that every bike I have that does not have a separator, it's totally down hill from the air box to a spigot.
    Im not looking at one of my 500 right now, but if the exit off of the crankcase goes down at all before heading up to the air box, a pool of gunk could form in the tube and possibly affect the breathing.
    In that case a simple T at a designated low spot with one more tube going down with the plug in it would give me piece of mind. Wouldnt need to be as big of hose either.
    #66
  7. RogueRC24
    Questions before I go mad? ALL CAPS IF I FIGURED IT OUT.
    Does an 86 require a fuel pump? Manual doesn’t say anything about 86. NO - yay
    Did I put these coils in wrong because my fuel tank petcock won’t clear all the coils. GOT IT, I WAS MISSING THE RUBBERS UP FRONT AND A LITTLE NUDGE ON THE COILS MAKES IT FIT.
    They bike will only run for a couple revolutions on its own and then stalls. Choke only seems to hurt. Adding throttle only hurts. ColdD recommended checking idle adjustments. Sure enough, but now she idles crazy high with no throttle or choke.
    All input is welcome. I feel like I missed something on the carbs.
    coils: image.jpg
    cylinder breather hose
    #67
  8. RogueRC24
    #68
  9. Colddevil
    Colddevil Member
    Wisconsin
    86 you're gravity-fed. No fuel pump.
    If choke is hurting it, it's possible you have the idle set Wayyyyyyyy to high. I did that exact thing when firing the 700 for the first time a few weeks ago. It'll fire hard for about 3 seconds then die. Back it way off and try it again if you're not certain where it should be set.
    #69
    RogueRC24 likes this.
  10. RogueRC24
    So now she wants to rocket to the moon with no choke or throttle while stone cold. I definitely fucked up the idle settings. Time to pull carbs I suppose. do no leaks count as a win?
    You were 100% ColdD. But I need to figure out what set incorrectly.
    #70
  11. Colddevil
    Colddevil Member
    Wisconsin
    Before you pull em completely, make sure that the throttle cable isn't binding up and not allowing it to go all the way closed. You've got adjustments both at the carburetor and at the right handlebar--so check both.
    The other time I've gotten something similar is when I really botched a bench sync. I couldn't get it to idle below 4k. If it's not your throttle cable binding or the idle set screw set too high, my money is on carbs way out of sync. If you do pull them, I'd give that another go just to rule that out.
    #71
  12. Colddevil
    Colddevil Member
    Wisconsin
    100%. Nothing is more infuriating than a leak! That's a victory.
    #72
  13. squirrelman
    after working on carbs set the initial idle speed adjustment screw by backing it off until screw just stops touching, then screw 1 turn in. will need further adjustment to get proper idle after running=1200 rpm.
    shouldn't need more than 20 seconds with choke on.
    #73
  14. RogueRC24
    Thanks dudes. It is now super bowl time, so next weekend for this follow up. Can’t say this wasn’t frustrating but the bike did actually run so there is hope!
    #74
    Couple late comments:
    Breather hose looks like it should be no problem with out the catch tank.
    No leaks def counts as a partial win.
    Do your throttle cables have any slack at the throttle housing?
    #75
  16. RogueRC24
    If I get home early today, then I will check the throttle cable connections. Overall the throttle cable is a little loose at the carb fitting, but it does seem correct.
    Thankfully these carbs are cake to get into position compared to the 750 so I am not dreading the reinstall if I need to pull them out again.
    I have to redo my fuel hoses anyway. I placed them with a central position from the fuel tank, when I really need them to run straight into carb 1 and T off to carb 3.
    I am also going to take a photo of my idle screw and see what you dudes think.
    Super appreciate the feedback from all of you!! The super bowl was ehhh. but it is 1 of my 2 days of the year to drink a beer, put my feet up, and eat whatever without any guilt ( always self inflicted). :) My wife makes a mean Beer Can Chicken!! She is the best!
    #76
    Cool. Let us know what you find.
    I could take or leave the Super Bowl. But if I'm home, sure whatever. Wife made a KILLER chili and cornbread. But she had to study, so it was just a buddy and me watching in the shop, glancing at VFRs. I did win $200 for the 4th Qtr / Final score tho. Hah!
    #77
  18. RogueRC24
    Yewwwwwww!wish video worked. She is a purrin!
    #78
  19. RogueRC24
    Idle is still high with full slack in cable. Idle adjuster is not touching either. It was running great until I blipped the throttle. Grrr throttle cable feels like it is snapping closed. All carbs appear to be equally synced, just high idle.
    Any other items of interest I should look at or pull the carbs again and check something that I am unaware of?
    Just a question but is the first carb butterfly permanent in its location? Can that be adjusted?All of the butterflies are covering the top most hole in the throat. Should they be below that hole? Hope this makes sense. No air leaks that I can find.
    also ran more normal before it warmed up.
    #79
    Sounds like you have a massive intake air leak. Especially since it shot up after warm and the first blip, classic symptom.
    Were these CA carbs? I can't remember. Confident you didn't roll over a boot lip on assembly?
    Do the carbs go in crazy easy? Sure you don't have 84/85 intake boots with 86 carbs? They are way easier to find and way cheaper than 86.
    Sorry, throwing shit out there. I've read and followed this whole thread, but I didn't go back and fact check my questions.
    Base throttle plate is positioned by the throttle screw. If backed out, it is ( or should be) closed.
    #80
