Rogue's VF500 rebuild or part out!!
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Nov 17, 2022.
  1. RogueRC24
    Back on two wheels and about to go at the calipers with new seals. image.jpg
    rc24dk, Pdeano65 and sixdog like this.
  2. Pdeano65
    Pdeano65 New Member
    Chicago
    Rogue, looks great. We are at the same spot in our Miniseptor fork rebuild. My rotors were dead so eBay to the rescue. I don't have the position sticker on the Trac adjustment knob but you do. On yours, what number is next to the little set screw on the side of the knob? Not sure how much difference is makes in different positions but would be nice to know. Thanks!
  3. RogueRC24
    #4 is the location of the set screw. The manual says that 1 is the least firm and 4 is the firmest. Looks good dude! it took a bit to get my rotors clean. The fork seal leak got into everything down there. All good now though. :)
    Pdeano65 likes this.
    Set screw on my 86 is "4"
    And not that it ultimately matters, but those are both "Right" rotors.
    Also, check your fitment of the speedo drive. Looks like you might have the limit tab on the drive housing in front of the fork slider tab, not behind.
    Nice. Hey Rogue, looking at the axle cap on your fork lower, it looks like there might be a gap in front. Just a reminder that Honda axle holders have a "Front" and that gets tightened completely first, and then you tighten the rear nut for your clamping force.
    Pdeano65 and squirrelman like this.
  6. RogueRC24
    Yeah I saw the F with the little arrow. No gap, just shadow. Although I didn’t know about the front first call out, now I know. Just kinda figured that is what I would want. Thanks dudes!
    Pdeano65 and Captain 80s like this.
  7. RogueRC24
    Oh and it seems obvious, but clean out the all of the banjos on these old gals. image.jpg
  8. RogueRC24
    This is how I like to flush and pre-fill the hydraulic lines. Inject straight into the the master with a little syringe. Sorry if this is repetitive. Still newb. First I fill the syringe with the old fluid and if is only dark but debris free I will force it down the line so it takes any ick with it. Then I clean the master. Once that is done then I put new fluid in the syringe and force that through to rinse fresh. Last is filling the master and injecting clean fluid once the lines are connected. Has worked well so far.
    I am going to try the new glass install from V4D once I get the right adhesive. image.jpg image.jpg image.jpg
    rc24dk and Pdeano65 like this.
  9. RogueRC24
    Sight glass replacement under way. Punch glass out and wire wheeled interior surface. Also placed a cleaning swab into master area to keep debris out.
  10. RogueRC24
    Alright wiring question. I have running lights and right side blinkers work as expected, but left flashes quickly but both bulbs work. What am I missing?
    Switch the bulbs L + R and see if the problem moves.
    RogueRC24 likes this.
  12. bmart
    bmart Member
    Charlotte, NC
    Are the dash indicators part of the circuit? Are those working?
  13. chuntera
    chuntera New Member
    Connecticut, USA
    So the "old" way to do this is replace the sight lens with watch glass.
    The advantage of this is the mineral glass will last longer, harder to scratch and won't yellow in the sun.
    The downside is the watch glass will probably need some sanding to fit, and then you have epoxy/seal it into place.
    The "new" way is to replace the aluminum bezel along with the lens. Lots of example videos can be found online.
    (eg. https://www.rockymountainatvmc.com/parts/tusk-replacement-brake-master-cylinder-sight-glass-p)
    The advantage is your are replacing the old nasty oring along with the lens. However the replacement lens are cheap (ie. thin) plastic that scratches easily and probably won't last long.
    Apparently the sight lens size varied over the years and trying to force it doesn't work.
    Pdeano65 and RogueRC24 like this.
  14. RogueRC24
    I will need to look at gauge cluster tonight once I switch the bulbs over. It was kind funny, because when I plugged in the lights one at a time they initially didn't want to work. Low beam worked but not high beam and then BAM! Same with each front running light. I think this bike has been sitting so long the electricity had to re-energize the wiring loom.
    Probably talking out my arse, but besides the fast blinking everything works. Thanks dudes!
  15. RogueRC24
    So I think it is just the bulb clinging to life.
    Poor guy. Put him out of his misery.
    bmart likes this.
  17. Pdeano65
    Pdeano65 New Member
    Chicago
    LOL, I just did this too. Joe's tutorial on V4dreams is an excellent guide. The sanding seemed pretty simple. The hardest part was getting the right amount of glue on there. I might replace the whole thing like ColdDevil suggested if I had t do it again but way better than before. Swift-B0193 11.jpg
  18. Pdeano65
    Pdeano65 New Member
    Chicago
    Sorry, I mean like chuntera suggested.
  19. RogueRC24
    Pdeano65, I would like to see your end result with the new glass when you have a chance. I think I need to work on removing the old o-ring still.
  20. RogueRC24
