Runs but not good!
Discussion in 'Mechanics Garage' started by Louis Robinson, Jun 19, 2019.
  1. Louis Robinson
    Louis Robinson New Member
    Whats does this adjust on carb?
    You need to host it at a video hosting site and then upload from there to here.
  3. Louis Robinson
    Any one know where this line goes to? 1985 Honda interceptor 700! Thanks
  4. squirrelman
    it's an air vent line and connects to nothing. who told you to remove the airbox bottom from the carb set ?? bad move as u may break fuel tubes.
    Thumbs likes this.
  5. Louis Robinson
    Ok so i found the problem! Was a bad seal! So i had to take carbs off! So i go and synchronized the carbs and now the idle will not come down, it only comes down to about 2000 rpms and will not come down anymore. The idle screw it all the way out and still don't change! Running good now though, just think i did something when i synchronized the carbs. Any ideas on what i did? Seen on a video that if u synchronized them in the wrong pattern that is what happens, any one know the right way to do that? Just been trying to get it running right so i can take my motorcycle road test thanks for all the help!
  6. Louis Robinson
    No i have never had a problem taken anything a part, just take your time and look at what u are doing! Trying to find the problem with this thing, every one is saying carbs! So that is the only way to see the carbs on this bike! Always have to take so much off just to check anything
  7. Louis Robinson
    No one told me to! It's the only way to see the carbs!
