RVF400 in the off-season
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Jan 25, 2025.
  1. RogueRC24
    Today I finished the wiring for my aux gauges and roughly mounted the upper fairing. Bike starts great and idles fine on the bench but if I blip the idle hangs. I went and tightened down all of the insulators again. But that made no difference. Must be a carb setting? Axle due Wednesday so no test ride but the rest of the bike is ready. image.jpg
    #81
    Generally speaking, it's a lean condition that causes that. Air leak? Vacuum line still connected to the petcock? Throttle cables not returning completely? Lean jetting situation with the pilots?
    #82
  3. RogueRC24
    Not sure where else air would get in. I did tighten the insulators about as much as I am willing to go and that didn't make a single dif. Vacuum line is new connected to the tank. Throttle cable is new and set appropriately, but I will verify tomorrow. I did switch out the mains, but not the pilots. Went a little smaller on the mains.
    #83
  4. RogueRC24
    Also completed the rear brake master bleeding with the rear wheel off. Cleaned and replaced the wheel nut to a nice anodized blue. All lights and signals work. Almost time to come off the bench!
    #84
    NorcalBoy likes this.
  5. NorcalBoy
    Hmmmm. Slide hanging up? Totally spitballing here...as you can prolly tell.
    #85
  6. RogueRC24
    I appreciate the input. I think I won't hit the panic button until after the test ride.
    #86
    As NB suggests, usually this.
    #87
  8. RogueRC24
    8138A17B-3C38-4534-9E19-8AA53B04C240.jpeg 4DE241DF-A944-407D-BEAC-92D9DB004D28.jpeg ECFD6CAC-A730-4F10-8581-F807438F5F8B.jpeg Hell yeah, thank you CMSNL! The cross reference was perfect and for $25 I fit a front axle from a 1997 Blackbird 1100xx. Front end complete, down to either a test ride, try to adjust air/ fuel mix screw (if I am not mistaken) or just re-jet to previous jets.
    Then she is complete on the rebuild. Almost but good for now. Last thing would be a full front caliper rebuild, but that is more money than I have. Lol
    #88
  9. RogueRC24
    Fack, no matter what I do I end up with a hanging or stuck 5k idle.
    -Set back to 118 main- no change
    -Replaced air/fuel o-ring and set to 2 turns out like it was before- a little change. Should I add more turns or take away turns?
    -Insulators are new and tightened- no change
    -New throttle cable with 0 pull - no change
    -Choke- not engage and stalls when I add choke
    -Air box on or off makes no difference
    -Idle adjust does make a difference only if I leave the vacuum tube that is supposed to go to the tank unplugged (I think). Should that be plugging that while running on bottle?
    -I didn't touch the vacuum ports on the cylinders, but I guess I could spray some fluid on there to see if that changes idle?
    - No fuel leaks on carbs, but would a cut vent cross tube o-ring cause issues?
    I just dont' know enough about functionality to diagnose. Help me Obi-wan your my only hope...
    #89
  10. NorcalBoy
    1.) Operating the choke creates a rich, or enriched, condition. Is the engine cold or hot when you operate the choke?
    1.) Should be plugged...it is an open vacuum leak, if not plugged into the petcock.
    I would start with plugging the vacuum line and go from there.
    #90
  11. RogueRC24
    I did need a little choke when it was cold, but just to verify if it was holding on I would add more when the bike was warm which would kill it, like I would expect.
    I was holding the vacuum line in my hand and plugging. I also verified that the tube was not cracked even though it is new. Seems in perfect shape.
    I may need to just pull everything apart and start over again. Could the o-ring between the plenum and carbs be the issue? I didn't have new ones of those. I will try and spray a little carb cleaner while running and see if the carbs gain or loose idle.
    Really not sure what else to do. Gonna be a long Sunday.
    thanks again for trying to help.
    #91
  12. RogueRC24
    Fucking found it.. The FACKING spring-loaded throttle assembly was not returning to full off on its own. 1mm of movement left, making the idle hang.
    Bike has all of the same symptoms until I push down with my finger on the assembly you connect the throttle cable to. Jeeeezus!
    That is the first time I have ever had that stick on a carb in 33 yrs. crazy. Can you lube that? ;)
    #92
  13. NorcalBoy
    Always try the most simple things first. :Boom:
    #93
    RogueRC24 likes this.
  14. RogueRC24
    fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuk
    yup. Well at least I built the carb correctly.....ish?
    #94
  15. RogueRC24
    image.jpg image.jpg What should the butterfly look like when closed? Should the little holes be covered?
    Or a slight gap? I would think closed all the way.
    I think i answered my own question searching on this forum...lol Maybe too much Redbull.
    #95
  16. RogueRC24
    Alright, I think I know where I messed up. I had the 2/4 carbs wound so tight on the sync (I must have rushed this part) that the #1 butterfly couldn't close all of the way. I went back through and loosened everything and started over. Now #1 is closing and they match inside each bore.
    I referenced squirrels post about setting base.
    Bike is now running correctly. f yeah!! more red bull
    Oh and the biggest lesson learned is how to properly install and remove V4 carbs. :) Getting good at it now.
    #96
  17. RogueRC24
    image.jpg Whew, she is running good down the driveway. Not sure I even need to work on the clutch. The new cable is helping out really well.
    #97
    Nice job. So you did the bench synch out of sequence?
    #98
  19. RogueRC24
    It would seem so. I didn’t really consider the fact that it would be in sequence. Newb for sure. Even at this age I am still learning. But I learn best from mistakes so now I should be good for a lifetime. Hahaha
    #99
  20. NorcalBoy
    As the Mandalorian's say......this is the way.
