RVF400 - NC35 White
Discussion in '3rd & 4th Generation 1990-1997' started by Diving Pete, Oct 1, 2018.
  1. NorcalBoy
    Lookin' good, Mr. Pete!
    #41
  2. Scubalong
    :Eek::Eek::Eek::Eek::Eek::Eek:Another bike......
    #42
  3. Diving Pete
    Long - well you needed one to ride so I thought options are always nice...:Welcome:
    #43
    Scubalong likes this.
  4. Scubalong
    Sweeeeet...
    Sent from my SM-N950U using Tapatalk
    #44
  5. Diving Pete
    Carbs now synched & the bike is running lovely. I love using the 90' tool as I no longer burn my hands in the V... Should have bought it years ago.
    It now starts first click & idles really well with the bonus of no fuel leaking any more - lol.
    Rear brakes all done - total strip / rebuild & new pads.
    Front brakes & lines now bled & working perfectly.
    Fairings & tank to be put on (have to find some brackets & bolts - ha, ha, ha,) so almost there. Hopefully this week..
    Just realised need new number plate - argh
    #45
  6. Diving Pete
    A bit more done - into the finishing straight.. Fairings on & complete.
    Had to make a couple of plastic brackets, & repair a small crack - but getting good at that now. I use Plastex & it really does the job.
    This leaves me with a few jobs to do.
    1. The Tank NEEDS to be stripped, sanded & repainted, - will order the full sticker kit from Image works this week. Basically the tank was badly stored & micro bubbles are in the paint. The rust is now cured & the inside looks like new but the paint will need fixing at some point. The glue used on the old now removed tank pad also has killed the paint in that area. This can wait a few months ... - I'd rather ride the bike.
    2. The Rear H panel between the lights I had to repair in 3 areas - again used plastex. This has had primer & a single coat of base (White). It needs 2 coats more of base & 3 coats of clear - to be done at the same time as the tank.
    3. Forks need stripping & rebuilding - Nothing actually wrong with them except I don't know when this was last done so not a priority. Have all the bits but time is against me - lol
    4. Change the tyres. Date coded 02/02 (feb 02 WTF!)
    So to get the bike on the road I need to:
    Machine polish & wax the front tank cover
    fit it on the tank,
    install & plumb the tank,
    Fit the air tubes,
    Fit the seats,
    Check the torque settings on all 3 brakes & axles
    Fit Number plate
    #46
  7. Diving Pete
    Part 2..
    Machine polish & wax the front tank cover - DONE
    fit it on the tank, - DONE
    Fit the air tubes,
    Fit the seats, Rear Seat done, front after Tank
    Check the torque settings on all 3 brakes & axles - DONE
    Fit Number plate - DONE
    Not far away..
    #47
  8. TL RVF
    TL RVF New Member
    Thailand
    Just joined the site. I have a 1996 RVF NC35, all stock, Mine has 14,000 km on it.
    Nice looking RVF OP!!
    #48
  9. TL RVF
    TL RVF New Member
    Thailand
    BTW, Cool bike lift you got there. I need one. I have the front and rear stands.
    Can you post a link to who makes that lift or some other pictures. I can probably make something up if I cant find it here in Thailand.
    #49
  10. TL RVF
    TL RVF New Member
    Thailand
    Here is my RVF after a morning ride.
    #50
    scottbott and Diving Pete like this.
  11. Diving Pete
    Thanks - this one is now its all back together - lol..
    Have moved onto dealing with no 2 at present - trying to decide what to do with this one - hopefully I'll get some nice pics this weekend
    #51
  12. Diving Pete
    Thats the Abba Skylift - not cheap, but very versatile & adjustable - the fact you can move it with the bike on it is a bonus..
    https://abbastands.co.uk
    #52
  13. Diving Pete
    Lovely - looks mint - Just like my no 1... lol
    #53
  14. Diving Pete
    So a little more updates...
    Not really good news but light at end of the tunnel.
    Fuel tank petcock is 'still' leaking fuel - even after rebuild & turned OFF.
    This is also causing the fuel to come through the floats (think I have a stuck float) & fill the cylinders specifically No: 1 - ARGHHHHHH
    The front brakes need 're-bleeding' - quick job that I'll do this week
    However,
    a used petcock is on the way to me - should arrive this week & I've also just found out I can buy a new one !! Thought they were NLA. May end up buying one anyway..
    The tank is off & so I'll clean up all the plugs
    Other than that its pretty ready to go.. - Once I've run it around the block to check it..
    Please bare in mind this had been sat in a garage & not moved for about 6 years - & its only done 400miles since 2006 !
    I'm optimistic... ha, ha, ha
    So some pics of a very clean bike...
    [​IMG]P1080943 by Pete Smith, on Flickr
    [​IMG]P1080953 by Pete Smith, on Flickr
    [​IMG]P1080954 by Pete Smith, on Flickr
    [​IMG]P1080955 by Pete Smith, on Flickr
    #54
  15. OOTV
    OOTV Member
    Sweet! Good luck with the peacock replacement, knowing that they are still available I know I would be buying a new one and keep the used one as A spare.
    #55
  16. Diving Pete
    I suspect that unless this 'used' one is in really good condition then that's exactly what will happen.
    I also have a spare tank (minus the petcock) so will potentially do that as well.
    #56
  17. Diving Pete
    Oh,
    Only found out that I could get a brand new one AFTER I'd bought the used one !!!
    After riding it today - It is lovely.... Had a few rides on it today - I'd almost forgotten how fast they lean - I've gotten used to the VFR800 (the Fat Bus) & having to muscle it about !!
    #57
  18. Brian Rodgers
    Brian Rodgers New Member
    Jarrell, Texas
    Would you give a report on the quality of the decals from Image Works?
    Any idea if they have a set specific to the RC45 ?
    Beautiful machine.
    Thanks for sharing.
    Brian
    #58
  19. Diving Pete
    Hi Brian
    Don't know if they have them for the 45 ¬! Its a little bit rarer than the 35 - lol
    Onto the decals from Image Works.
    I have no previous experience with decals so please bear that in mind - There is a learning curve to fitting them. Once I'd 'realised' that, I found them excellent to the point I have ordered another set for another bike from them.
    The colours are a great match - no variations from what I'm expecting & I'm very, very happy with the quality.
    Now it does seem like I am recommending these (& I am) but I have nothing else to compare them too - I've never used other companies graphics.
    #59
  20. Diving Pete
    Replacement petcock turned up yesterday & was a little disappointed that it was missing a couple of internal parts - arghhhh
    However, I stripped my existing petcock after draining the tank and switched over the good parts to the 'new' body.
    The inside looks a million % better, although very dirty on the outside but nothing that won't clean up.
    On refilling the tank & reassembling the petcock it seems to work perfectly so phase 1 complete.
    #60
