Shell Rotella motor oil???!!??
Discussion in 'Mechanics Garage' started by clintjennings, Aug 2, 2016.
  1. Badbilly
    Great filter choice. Eeek!
  2. 34468 Randy
    Stay away from these fucking filters! There is not one credible positive reference on this forum about them, but tonnes of negative. Even cheap Fram fiters would be a better choice.
  3. speed
    speed New Member
    Harbor Oregon 97415
    I once knew of a friend of a friend of a friend that was 3ed cousin to a friend of a friend of a friend that knew a guy that said he liked it, just saying.
  4. Allyance
    Allyance Insider
    Germany
    East Bay, California
    They fail and spew oil all over rear tire!!!!!
  5. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I run the 5W40 T6
    Sent from my SM-G930W8 using Tapatalk
  6. 34468 Randy
    Same here. Use it as well in two Civics and my Duramax. Just one open bottle of oil laying around in my garage. Not 4 or 5.
  7. OREGONVFR
    OREGONVFR New Member
    Okay then .
    Good thing I own a euro/asian auto shop ..... Ill just return it for a Napa gold filter then .
    In my industry we shy away from fram ... just thought a K&N would be a go.
    Guess I learned quickly before a failure .
  8. 34468 Randy
    Ya. I am not a fan of Fram either but I would use one of those over the K&N oil filter any day of the week. I have K&N's air filter on my bike and though I am sure it is fine, at least those who seem to know more than I, claim there is a performance increase with them, I am turfing mine in the trash soon as I run out of the cleaning and treatment solutions for the filter. I can't be bothered Cleaning, then waiting for it to dry, then applying the treatment, then waiting again before I am able to ride if I so wish.
  9. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I like the Wix filters myself and I use HiFlo Filtro OEM replacement air filters
  10. OOTV
    OOTV Member
    Not that I want to revive an old thread but I thought this was kind of funny. Revzilla's Common Tread did a little story on Oil and the top comments are almost all about Rotella T6! Seems a lot of people have gravitated to it. The power of the internet I guess. Also mentioned in the story is how Synthetic oils can actually "find" leaks, meaning that with conventional oils, which has thicker molecules, you may not see a leak. However, with the smaller molecules of synthetic oils, the leak may start and thus it "finds" where a leak can happen. This is what I was referring to in another post I made. Anyway, odd that one of the guys says he put it in all his vehicles, including his Ducati 900SS/SP and "nothing but positive results", my experience was not as good with it in my 900SS.
    Why things are the way they are: Motorcycle oil
  11. Allyance
    Allyance Insider
    Germany
    RE: Any pure synthetic, from Dave Mann (37 years as a professional lubrication engineer):
    Synthetic Lubricants, Seals and Leaks
    You may have heard the myth that synthetics cause engine seals to leak. Synthetics absolutely do not cause seals to leak, they simply may only possibly reveal an existing leak path and a seal that has failed and is in need of mechanical replacement. Either the seal lip is worn down or the seal is hardened and cracked from old age, heat and ozone. If you have an older higher mileage engine that has been running petroleum oil for its entire life, and it also leaks, for example around the rear-main oil seal, then chances are it may leak the same or possibly more with synthetic oil. Synthetic oil is naturally cleansing and high detergent and will remove internal engine sludge and varnish deposits, but synthetic oil does not cause leaks. This is commonly referred to as a false seal.
  12. Badbilly
    Another good reason to not buy a Harley IMO.
  13. Badbilly
  14. Lint
    Lint Member
    Simi Valley, Ca.
    Sounds so nice, he said it twice...
  15. Lint
    Lint Member
    Simi Valley, Ca.
    Again. :hss:
  16. sunofwolf
    sunofwolf New Member
    Harley have two different types of oil containers, that means they have more places to leak, but that is a excellent way to have the right oil.
  17. Gator
    Gator Member
    Ever look at the floor of a Harley dealership? Oil all over the place or stains where they have to keep cleaning it up. lol
  18. OOTV
    OOTV Member
    Nope, never stepped foot into a Harley Dealer, probably never will! :wink:
  19. Allyance
    Allyance Insider
    Germany
    Years ago it was the English bikes that were nortorius for leaking!
  20. Gator
    Gator Member
