shock linkage paint
Discussion in '1st & 2nd Generation 1983-1989' started by Don key268, Sep 17, 2018.
  1. Don key268
    Don key268 New Member
    greetings,
    has anyone been able to find an acceptable paint for rear linkage? i have been comparing many brands and none appear close. If they are they seem "soft" and not up to the demands needed. I only say that as the steel linkage is beat up but the aluminum shock arm is pretty good shape. the paint has a sheen to it
    thank you in advance
    Dupli-Color Wheel Paint and Clear Coat is certainly up to the task. It sprays nice, comes in good colors and is very durable. I use it for nearly all my chassis components, including calipers, brackets and master cylinders, insides of rotors, linkages, triple clamps, etc.
    Don key268 likes this.
  3. Don key268
    that is great to know! i wondered if it was strong enough. i painted some other pieces with vht univ aluminum and it was very close for fork leg bottoms and radiator grill. its these other pieces that are different and I am trying to get ideas on what others have done or used.
    What bike by the way?
  5. Don key268
    I guess I should Have said that from the very beginning , oops. 86 vfr750
    All 86 fork lowers are black. Pictures are needed at this point. (Actually they are always required). :)
  7. Don key268
    I actually haven’t done the forks yet. Just tested color on rad grill first. I tested small area on linkage and didn’t like at all
    Nice front end. Details please.
    900RR? CB1000 The Big One?
  9. Don key268
    good eye! 93 900rr front end with 97 f3 wheel and rc51 calipers. A lot wear and tear has me going through and getter her good again.
    A lot of the universal silvers tend to look a little "cheap" for me, but can have their place.
  11. Don key268
    The paint that was used for the arm/linkage Looks like galvanized steel . I know it is not but that is what it reminds me of. So it has a slightly reflective sheen to it oh.
    Wander a few paces left or right in the Auto Parts store and look at some of the Dupli-Color made to match some factory automotive finishes. You can find some unique colors that are also very durable.
    sixdog and Don key268 like this.
  13. Don key268
    You have no idea how ironic your pics are. Btw, I didn’t have time to fix that case and now it’s bothering the hell outta me. Good looking bike you got there
    I had to blend the shit out of the right case, and I'm sure it's thin. But it's symmetrical and damage "free". Think my damage was more on the "HONDA" and less on that lower edge.
    Fix it. Now is the time.
  15. Don key268
    I noticed immediately that you had shave that off and cleaned it up. You did a great job. Thank you for pointing me in the Dupler color direction. I think I may have found a color I’m looking for so I will try it This weekend and see how it comes out. Thank you for the pics too. I now know I also need to scrub a little more. Damnit that thing is clean!
  16. BristolVFR
    BristolVFR New Member
    What color is this Don key268??
  17. Don key268
    it’s cerakote burnt bronze
    BristolVFR likes this.
