should i pull the trigger?
Discussion in '5th Generation 1998-2001' started by loosenoose, Aug 4, 2017.
what do you think i should i do?
Poll closed Aug 6, 2017.
  1. try to be cheap and fix the red
    0 vote(s)
    0.0%
  2. spend more for a better bike that still needs about $400 dropped into it, at least
    0 vote(s)
    0.0%
  3. just keep the cbr250r and be happy with what you've got and save your money for a solid vfr purchase
    3 vote(s)
    100.0%
  4. other:
    0 vote(s)
    0.0%
  1. thtanner
    thtanner New Member
    Orange County, CA
    OEM stators only (why would you want , FH020AA or SH847 from http://www.roadstercycle.com/
    You can also get the FH020AA used off ebay 'FZ-09 Regulator Used"
    #41
  2. DaHose
    DaHose New Member
    Napa, CA.
    You will be quite happy with the Q3's. It's one of the few tires that people actually ride to the track, run a full track day, and ride home. I went the Roadsmart III route with my new rear, but the front is still an older Q2. The only reason for a RSIII, was that I do ride some in winter (Napa, CA has pretty awesome weather), and in the wet the Q2 is not the best. I figured that the extremely positive write ups of the RSIII made it the logical choice when my rear needed replacing, and I will replace the Q2 with an RSIII down the road. I will say that the combination of Q2 front and RSIII in rear is totally confidence inspiring for summer riding.
    As to working on your bike. I have been the only person to touch my motorcycles since I was about 22, so I say have at it with the VFR.
    Jose
    #42
    loosenoose likes this.
  3. loosenoose
    loosenoose New Member
    i used the goop and torqued the bolts to the right spec and it no longer leaks. i filled up the gas tank and SHE LIVES!!!!!!
    sadly, i cant take her out for a victory run, as the new tires arent in, and the front looks deadly.
    #43
    Bubba Utah likes this.
  4. Jim McCulloch
    Jim McCulloch Member
    Ok, I found one finally! I bought the white one that had been on CL for several weeks. 2000 model Gen 5. It was $1300.00. Did not run when I looked at it but it magically started up after screwing around with it for a while. Needs a lot of TLC as you can imagine. Keep in touch.
    #44
  5. loosenoose
    Good deal! Keep us posted on your progress
    #45
    Jim McCulloch likes this.
  6. Bubba Utah
    Bubba Utah Member
    Utah
    I have never interchanged tires from front to rear. Are you saying that it is a good idea? I also do not keep fronts on when the back is bad. Am I wasting good money?
    #46
  7. dhinson66
    dhinson66 New Member
    Germany
    Nashville, Tennessee USA
    I have had Dunlop Q somethings on my'98 since they first came out. I got tired of buying a new rear every 9 months so went with a Michelin rear the guys at the shop recommended. So now I have a fairly new Dunlop Q2 on the front and a new Michelin on the rear and I love the combination. This is the 1st time I've had different brands but I don't notice anything negative.
    Sent from my GT-N5110 using Tapatalk
    #47
  8. loosenoose
    i remember the wear being fairly quick on the qualifiers i had on my first sv650. it was a GREAT tire other than that
    #48
  9. Diving Pete
    I've never mixed any of my tires - but then again I generally wear them out at the same time... about 4000m
    #49
