So I test rode a VFR today...
Discussion in '5th Generation 1998-2001' started by BWeiss, Jul 1, 2008.
  1. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    I took a 99 on a ride just an hour ago. I'm smiling ear to ear, but that may be the rush of getting back on a motorcycle coming from a cruiser (shadow ACE). I really want to pick it up but there may be a few issues that will affect my long term happiness. The bike looked to be all stock save a jardine exhaust, I don't believe there is a Power Commander in there. It has a little over 14k on it.
    1. The throttle was not very smooth. It seemed like it was either on or off especially when compared to the Shadow and an SV650S I also rode which were butter smooth. Is this normal? Any way to adjust or fix this?
    2. The front brakes were really grabby. The pads may be new which would explain this, but if they aren't is there a way to adjust the bias or power of the front brake? I know the brakes are linked, but it was only grabby when using the front lever.
    If there are ways to tinker with it and get it to where I like it, I'll be joining the VFR community very soon. Thanks for any help!
    -Brooks
  2. Britt
    Britt New Member
    Westmont, IL
    In my personal opinion the brakes sound normal - when my dad tried my VFR he said the same thing. He was used to fairly weak brakes, and the brakes on a VFR are pretty strong.
  3. Action
    Action New Member
    Albuquerque
    I agree with Britt on the brakes. I use two fingers to brake and still have plenty of stopping power. If you’re used to a bike with weak brakes or a bike that has a lot of travel in the lever the VFR brakes will seem grabby. If that is not the case the brakes may need to be cleaned/serviced. As far as the engine, most of the fifth gen guys say their bikes are some of the smoothest out there. Could there have been some play in the throttle cable?
    Action
  4. drewl
    drewl Insider
    Virginia Beach, Va
    My first gear is jumpy, you need to be very smoothe on the throttle at first. I did just adjust the throttle cable that made a noticeable change, but still need to be smoothe in first.
  5. BWeiss
    Rancho Cordova, Ca
    one question...what gas do these things take? Reg or Prem?
  6. bitterpil
    bitterpil New Member
    Northern Virginia
    They take regular.... but lots of guys run Premium.
    The brakes are strong... I agree that coming from the shadow they sould feel grabby.
    The jerky throttle is somewhat normal and takes some getting used to. These bikes have touchy response. Not sure it wouldn't be\ just as touchy on other more sporty bikes.
    I have not ridden the SV650. I have ridden the shadow ace and comparing the two is almost impossible. The sahdow is almost a 80Lbs heavier and tops out at 38HP compaired to the 470Lb or lighter 98+HP. All 750s aren't created equal. I think this could have something to do whith what you are noticing.
    I hope this helps.
  7. mello dude
    Romania
    Your coming off a shadow which is a laid back ez going type of bike to a VFR which much more of an athelete. Things are supposed to happen a bit quicker on the viffer and it takes a bit more focus to ride.
    The low end can be tinkered with a bit with a PCIII to smooth it out.
    Same comments for the brakes - you could adjust the lever so it engages closer to the handle bar. Maybe that would help you out.
    I just mainly think that this is a very different type of bike for you and it will take a bit of time to get accustomed to it.
    BTW the '99s are supposed to be the most desireable 5th gens.
    Good luck,
    MD
  8. bitterpil
    Northern Virginia
    I think I may given the wrong impression on the throttle response of the VFR. I was referring to the touchyness of Fuel injected sports bikes and I think you might be experienceing something different.
    If you are trully feeling a jerky feeing when in lower gears then there is the possibility the chain is too loose. The bike has a lot of power and when taking up even the smallest bit of slack on acceleration will add a jerky feeing. Have the guy adjust/tighten the chain then take it for another ride.
  9. BWeiss
    Rancho Cordova, Ca
    Well, I made the purchase yesterday. I have now owned her for about 12 hours now, and its pure love! Brakes and Throttle have smoothed out already. Some little gremlins must have made adjustments to the bike last night.:wink:
  10. drewl
    drewl Insider
    Virginia Beach, Va
    Rock On. It gets better all the time.
  11. ILVFR75
    ILVFR75 New Member
    Illinois
    Gremlins acting in a positive manner? Awesome. I thought they just tipped your bike over like in the TV commercials...
    Congrats on your purchase, you'll love your Viffer.
    Cheers,
    Jeff
  12. Scubalong
    Good choice
    Congratulation on your new bike. Now keep on riding you will love it.:sportbikesmile:
  13. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    Welcome aboard.
    post some pics. we wanna see.
  14. BWeiss
    Rancho Cordova, Ca
    Oh, that was already planned. I wanna show her off! I got home and it was too dark, so I'll get some today.
  15. mello dude
    Romania
    A few months from now youll say " what was I complaining about?". Youll wonder why you thought brakes/throttle were weird.
    Congrats! Welcome!
    MD
  16. drewl
    drewl Insider
    Virginia Beach, Va
    Where are you located, by the way? Always fun to hook up with other VFRs.
  17. BWeiss
    Rancho Cordova, Ca
    I'm just a little more than a stone's throw from you, down in Sacramento. We'll definately hookup some time.
  18. Alex_V
    Alex_V New Member
    And coming from a TZ125 I thought 02 VFR brakes were pure sheit :) Its all what you are used to
  19. tcarroll
    tcarroll New Member
    Shelburne Falls, MA
    Welcome aboard brother. My '99 is just a bit abrupt in first gear also.
    Yes the brakes are strong. As you've already noticed, you get used to it.
    As for the fuel.... oh boy hear we go again.
    Manual says 86 minimum. I run 88 or 89.
  20. whitesmokeyzf
    whitesmokeyzf New Member
    Albany Oregon
    It seams that its all about what you are used to riding. I had five bikes in the garage last year Hayabusa, R6, GSXR, the VFR feels very smooth and manageable & tame to me but agressive compared to my road king.
