Soft Luggage
Discussion in '6th Generation 2002-2013' started by 'BB', Jan 2, 2011.
  1. 'BB'
    'BB' New Member
    Texas
    I am thinking about getting some GIVI soft luggage, and am worried about melting them on the mufflers. I have seen some brackets that have been built, but my question is this... Has anyone seen, tried, or known someone who tried to attach heat shield material to the back of the bags to keep them from melting? If so did the material they used stop enough heat transfer to keep from melting the bags? I have found some cuttable adhesive backed heat shield material that is plyable and is rated for temps up to 1750F for a reasonable price, but have no idea how much heat actually transfers through.
  2. 34468 Randy
    Are you stainless steel heat shields still on the bike. If so, you should not have an issue. I rode about 3400 miles round trip twice with my soft Cortech and they didn't even come close to being an issue.
  3. woobie
    woobie New Member
    Beamsville, Ontario
    I rode down to Deals Gap and back with a set of motopak softbags on with no extra shielding and they performed great with no hear damage.
  4. DAN-SLO
    DAN-SLO New Member
    I use GIVI soft bags for 5-6 years,no problem due to overheating..
  5. joshbea6
    joshbea6 New Member
    Canal Winchester, OH
    are you running stock or aftermarket mufflers? I know with my pipes, I can put my hands on the exterior of them after a long ride an not scorch them, so if my hands are ok, soft bags will be too.
  6. Scubalong
    Cebu one of the member on this forum place some adhesive over the exhaust, the bags work fine but put stain (Burn mark) on the nice staintune exhaust.....
  7. 'BB'
    'BB' New Member
    Texas
    Running stock mufflers. I have just heard horror stories about them sitting on the exhaust and melting on long rides. I am about to make a 1600 mile trip from Houston through the Ozarks and back and just don't wanna be that guy who has it happen to him.
  8. 34468 Randy
    You should be fine so long as the heat shields are in place. Just make sure the bags and their straps stay clear of the inner pipes where the heat is. There should be sufficient air movement between the pipes and the heat shield to keep the shield cool enough to prevent burning or melting of the bags.
