Solution for drooping rear signals?
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Apr 19, 2011.
  1. squirrelman
    THERE is NO aftermarket set of lights as high quality and solid as the Honda originals !
  2. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    ...and that is why I suggested the original HONDA 600RR turn signals, they're only slightly more aerodynamically shaped but bolt right on.
    :biggrin:
  3. squirrelman
    only mentioned it so others might know.....
  4. invisible cities
    invisible cities New Member
    new york
    A great suggestion.
    Will all years of the CBR600RR work? Thx.
  5. hopit88
    hopit88 New Member
    If you MUST have a stock looking signal, these look better than the originals by far.
  6. stewartj239
    stewartj239 Member
    Syracuse, NY
    Yes, this will work. For my R, the signals only had a slight droop, so I swapped sides front and rear. You simply have to disassemble everything, swap the stalks and then reassemble. Captain 80s is right though, no wires should have to be cut.
  7. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    That's what I do. As mentioned, newer ones are a direct-fit and not a bad idea either.
  8. slowbird
    slowbird Member
    Toronto, Ontario.
    I'm curious about this too.
    Also how they mount up. The diagram in bikebandit shows something different then how the 2nd Gen mounts.
  9. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    I don't know, mine were off an '03 RR. I'd suspect all years of Honda's stalk signals have the same mount.
    The pair I bought cost $33 with shipping.
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    I purchased replacement rubber stalks off ebay but the screw holes don't line up.
    I'll see if I can find some cheapy RR signals.
  11. auxpowerunit
    auxpowerunit New Member
    Tampa, FL
    Oh, this one is easy ! I just did this on my VFR 750 last month.
    The rubber supports are symmetrical. So, all you need to do is swap the right rubber support with the left one !
  12. RobVG
    RobVG Member
    White Rock BC
    I think I may have come up with "a" solution. Make a gasket out of a piece of inner tube. Cut a teardrop shaped hole so the piece will slip over the rubber stock- the part that slips into the housing. It's ok if you have to stretch it a little. Trim the outside with some sharp scissors. Don't trim it with it assembled, you'll cut through the gasket (ask me how I know).
    No more droop on the 700.
    Edit: this may not work on the OP's problem. Mine had a small gap between the stalk and the housing.
    I don't know what's going on with his.
  13. captb
    captb New Member
    I modded 600F2 turn sigs, like the Japan spec VFR has. Lightweight and no way they can sag.
  14. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    Gorgeous bike.
  15. GigemVFR
    GigemVFR New Member
    TEXAS
    WOW! That bike is awesome!
  16. captb
    captb New Member
    Thanks for the positive comments! It's been running flawless for over 5 years now.
    Here's my SL350 I restored a few years ago, lots of mods, weighs about 300 lbs, does the ton easy and flicks around like a SM.
  17. Lint
    Lint Member
    Simi Valley, Ca.
    Try two Viagra. :courage: That ought to fix all kinds of drooping
  18. captb
    captb New Member
    Avgas runs nice!
  19. artee
    artee New Member
    Rochdale,
    Try vtr1000 superhawk indicators.
    Roger
  20. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    hopit88- That VF1000R just doesn't look right with those signals! I'd be willing to rescue you by taking that bike off of your hands, as a favor to you, of course! I'm not sure how you can stand to ride it!
