Sorry another charging question
Discussion in 'Mechanics Garage' started by Darth Vader, Apr 29, 2015.
  1. JTB488
    JTB488 New Member
    Any pics of your R1 r/r mod??
  2. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    No, but it's pretty straight forward.
    I'm now getting 13.1v at idle with lights on, and 14.4v at 5000rpm.
    I installed it as the original, but with only 1 bolt with nylock nut in the left hole, it holds fine.
    I also had to cut a bit of the top left fins to make it fit without them hitting the plastic.
    All connections soldered and a new positive cable with fuse directly to the battery.
    I've already updated all my earth block, cables and frame earth with soldered cable lugs.
    If I get time, I'll pull the rear off on the weekend and take some pictures.
    Once you bolt the new R&R in place, you can sit the rear plastic on and you'll be able to see where you need to cut some fins off.
  3. Darth Vader
    Darth Vader New Member
    melton mowbray
