Spark plug change interval (86-87)
Discussion in '1st & 2nd Generation 1983-1989' started by savedrider, Jan 16, 2008.
  1. savedrider
    savedrider New Member
    Southern California
    Does anyone know why the factory manual states to replace the spark plugs every 4000 miles? I usually think of plugs as something that lasts a long time. There are notes that mention 86-87 model years only. What is unique about these engines that require such frequent replacement?
    I've had my current plugs in for almost 12,000 miles. I pulled them and they look good to me.
  2. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Pull them every year to inspect and so they don't become stuck in the heads. If they look good, I'd put them back. My '82 Sabre has had the same plugs in it since 1989!! 35,000 miles!! They still look fine.
  3. squirrelman
    Misprint or bad translation from Japanese:confused: numerals.
    SMALLER plugs on newer models require far more frequent replacement than on '86/'87, so maybe refering to that??
  4. savedrider
    Southern California
    I thought the exact same thing. Trouble is the Clymer manual says the same thing.
  5. squirrelman
    Clymer usually just copies, so if factory manual is wrong the same error will be in Clymers too.
  6. savedrider
    Southern California
    Trouble is they denote "86-87" model years only. Implying that other years have standard change intervals.
  7. squirrelman
    I just looked at my OFFICIAL Honda Service Manual and was SURPRIZED to see that it calls for replacement, as you state, at 4000 mile intervals!! Makes no sense to me either.....
    I have found a couple of small, uncorrected errors in the manual previously, but not like this!
  8. eddievalleytrailer
    Jonesborough, TN
    You're right. Clymer would never stray far from the factory.
  9. fuldog
    fuldog New Member
    Pacifica CA.
    I've owned several '86 - '87 vfr's and have never had to replace plugs any sooner than 15k miles. Even then they looked fine and were within spec on gap. BTW, be sure to put an anti sieze coating on the threads when installing and don't overtorque them.
