Spark plug question...
Discussion in '6th Generation 2002-2013' started by 91talon, Jan 29, 2013.
  1. nookiaz
    nookiaz New Member
    Denmark
    Montreal
    Sorry to ask & you may call me stoopid. I just got these plugs for my 5th gen & can I just go & install them as is or do I need a thingy (cap?) that goes on top? Or I can use the cap on the old plug & screw it on the the new plug & go install?
  2. VFR Love
    VFR Love New Member
    New York
    Match whatever you had before and yes you can reuse the cap thingy. The plugs should have come with it but it doesn't wear out.
  3. TNRabbit
    TNRabbit New Member
    Woodford, VA
  4. nookiaz
    nookiaz New Member
    Denmark
    Montreal
    Thanks VFRLove! & no deals for me as I wasnt that fortunate: got them for Can $12.71 a piece :(
  5. VFR Love
    VFR Love New Member
    New York
    I use needle nose to tighten mine on. They tend to loosen easily.
  6. VFR Love
    VFR Love New Member
    New York
    Just don't use pliers on the porcelain (white part)!!!
  7. Fantastic!
    Fantastic! New Member
    Been using the CR9EHIX-9 in my 6th gen no problems.
  8. squirrelman
    Best practice is to always lube plug threads lightly, using motor oil, anti-seize, or bearing grease.
  9. TNRabbit
    TNRabbit New Member
    Woodford, VA
    I installed mine without the cap; is it required??
  10. VFR Love
    VFR Love New Member
    New York
    It depends on the plug wire boot. Some are meant to be on the bare threaded shaft, others need nipples. Lol
  11. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    They are dimensionally the same minus the missing plug terminal.
  12. Fantastic!
    Gotta pay a premium for that plug terminal too!
  13. nookiaz
    nookiaz New Member
    Denmark
    Montreal
    How much can a plug terminal cost?
  14. VFR Love
    VFR Love New Member
    New York
    Just re-use your old ones if so equipped.
  15. Lint
    Lint Member
    Simi Valley, Ca.
    I called NGK and the plugs that I bought; CR9EHIX9 are definitely the wrong plugs for my bike, as they have thread the entire length, whereas the IMR9B9H, the specified plugs have thread that is only 12mm, vs 19mm and the guy I spoke with said that the extra thread length of the CR can get covered in carbon and strip out your spark plug threads in the heads. This has not happened to me, but I only have about 10K on them. Soo, yeah. I'm going to change them.
